PICS of my engine carnage, good stuff!!!
Old Jun 25, 2008 | 06:45 AM
  #41
signal12's Avatar
That must have sounded good when it came apart...
Wow
Old Jun 25, 2008 | 07:06 AM
  #42
brad8266's Avatar
Originally Posted by Halloran
In all seriousness though the only thing that can cause that is a casting flaw of some sort straight from the factory. Or like above poster said about hitting a rock and then having it start to slowly weaken the block until it just decided to give out. Did you notice any oil leaks or anything before it broke like that or did it just go boom?!
I dunno about a casting flaw because that engines got some miles and time on it. A casting flaw would have probably showed up earlier like when I was spraying.
Old Jun 25, 2008 | 09:00 AM
  #43
GuitsBoy's Avatar
Thats the first picture ive ever seen of a block split in that fashion. Good work. Best of luck with the new build.
Old Jun 25, 2008 | 11:00 AM
  #44
quick346's Avatar
maybe the t-chain broke and and built up in that corner and broke the block.
good luck on the new one
Old Jun 25, 2008 | 11:06 AM
  #45
brad8266's Avatar
Thats very plausible.
Old Jun 25, 2008 | 11:21 AM
  #46
slowandrichws6's Avatar
thats what i like to call doin work!
Old Jun 25, 2008 | 11:46 AM
  #47
krill's Avatar
That LS1 is broken.
Old Jun 25, 2008 | 12:17 PM
  #48
TT632's Avatar
Does the engine still spin freely?
Old Jun 25, 2008 | 02:42 PM
  #49
SIC LSX's Avatar
hell yeah that's how you do it!
Old Jun 25, 2008 | 03:13 PM
  #50
dlove's Avatar
just turn the radio up. that will fix it
Old Jun 25, 2008 | 03:42 PM
  #51
cantdrv65's Avatar
Post
My guess is you had some piston to valve contact in the past that stretched, cracked or weakened the chain. The chain then busted, wedged between the block and crank gear and ripped the front of the block right off. After that kind of hit I'd be sure to very closely inspect and test the entire rotating assembly obviously.
wow just wow! Most impressive!
Old Jun 25, 2008 | 03:44 PM
  #52
cantdrv65's Avatar
Post
Ya beat me to it! Thats the only way that it have happened IMO.....
Old Jun 25, 2008 | 03:45 PM
  #53
Assassin66's Avatar
damn dats fkn crazy
Old Jun 25, 2008 | 04:14 PM
  #54
gold98Z28's Avatar
im not buying the rock unless it was a stationary rock the the car stopped on at one time, i bet the block came from a hard hit car that had stressed the block from a hard front impact at one point of its life
Old Jun 25, 2008 | 04:20 PM
  #55
brad8266's Avatar
No, the pieces that are still just sitting in the front are holding it up a bit.
Old Jun 25, 2008 | 04:21 PM
  #56
brad8266's Avatar
There was no contact in the past, I know that. I think they chain just weakened from repeated high rpm use.
Old Jun 25, 2008 | 05:38 PM
  #57
cantdrv65's Avatar
Post
What are the cam specs and springs?....just curious.
Old Jun 25, 2008 | 05:48 PM
  #58
ShortChevy's Avatar
Damn, that is crazy. I sure as hell havn't seen anything like it.
Old Jun 25, 2008 | 07:21 PM
  #59
LS1-NAVY's Avatar
time for a boosted 408 :x
Old Jun 25, 2008 | 07:26 PM
  #60
brad8266's Avatar
eh, no
