TFS heads milled to 58cc/compression ratio?
Old Jul 12, 2008 | 09:26 PM
porsche914ls6's Avatar
Default TFS heads milled to 58cc/compression ratio?
I'm seriously considering dropping some cash on a pair of TFS 215cc heads for my 346 shortblock running Mahle pistons w/ 2cc valve reliefs. They are stock OEM 3.898 diameter. My question is this: What will my compression ratio be with milled TFS 215cc heads that currently have 58cc combustion chambers? Will I have any room left to clean these heads up on a mill in the future should they need it.
Old Jul 13, 2008 | 07:53 AM
Anyone with 58cc chamber size... what is your compression ratio?
Old Jul 13, 2008 | 09:36 AM
purdueranger's Avatar
What thickness gasket are you going to be running. with a .040 thickness gasket it going to be in the 11.40 SCR range. this is a rough estimate so anyone who comes up with a more precise mesurement, feel free to correct my calculated number.
Old Jul 13, 2008 | 10:19 AM
Jordan S.'s Avatar
I have 59CC trick flows with a .040 gasket and -4CC mahles. I'm at 11.2:1
Old Jul 13, 2008 | 10:31 AM
I'll be using the stock 04 ZO6 MLS head gasket. I'm not sure how thick these gaskets are. Did you have any intake manifold fitment issues? I've read that GM likes to shorten the dowel pins to help mate the manifold more easily.
Old Jul 13, 2008 | 02:52 PM
ssvolvo's Avatar
How heavy is your car?> Lighter the vehicle the more compression you can get away with.
Old Jul 13, 2008 | 03:21 PM
Default tfs 215cc
It is 2400lbs. It is in a non standard non chevy car (Porsche 914).
Attached Thumbnails TFS heads milled to 58cc/compression ratio?-my-914.jpg   TFS heads milled to 58cc/compression ratio?-rock-falls-9.9.06.jpg
Old Jul 13, 2008 | 06:18 PM
PONTIAC SLP's Avatar
you should write , pistons and thickness gasket specs to calculate the compression ratio , there are some sites u can calculate the CR , just search
Old Jul 13, 2008 | 06:19 PM
here u are : http://www.c5frc.com/calculators/Com...Calculator.htm
Old Jul 13, 2008 | 09:37 PM
405HP_Z06's Avatar
Here you go:
Old Jul 14, 2008 | 08:48 AM
Thanks guys for all the help. I appreciate it!
