Shop vac = clean head removal
1 Post
Share a little tip I got from my friend Brian:
When doing a head removal....after removing the H2O pump, use a wet/dry vac and "vacuum" the excess coolant from the H2O pump ports to the cylinder heads. I did this for a minute per side and got a good gallon of coolant in the shop vac.
Removed the heads.......no mess at all. Nota drop. I was clean, garage floor was clean. It was great!
Anyhow, it's easy and works. Figured I'd pass this on
