Is this the correct way to calculate lifter preload?
Old Aug 27, 2008 | 02:41 PM
Mike96z's Avatar
Default Is this the correct way to calculate lifter preload?
I have used the information ive found to calculate my lifter preload but to be sure ima use a pushrod length checker after I get it all together. Here is what I have calculated it as being.
7.380 Stock Pushrod
0.025 LS6 Cam Base Circle Diff (.050" Total)
-0.060 LS7 Lifter cup is .060 shallower (FIXED)
7.345 My Pushrod Size
0.080 Plus Preload
7.425 Total Pushrod Length
Isnt adding the preload to the pushrod size correct?
Old Aug 27, 2008 | 03:45 PM
vettenuts's Avatar
Are you sure the LS7 lifters are a different length? First I have seen that they are.
I thought you were milling, that isn't included.
To answer your other question, preload is added to pushrod length for a fixed fulcrum rocker.
Old Aug 27, 2008 | 03:48 PM
Mike96z's Avatar
Stock rockers. The LS7 lifter isnt actually longer (my bad) but the cup depth is .060 shallower so that adds into the equation. Im no lnnger gonna mill.
Old Aug 27, 2008 | 07:01 PM
JPH's Avatar
JPH
Must check in person, and not on piece of paper. Things change once in place.
Old Aug 27, 2008 | 07:12 PM
Mike96z's Avatar
and i will do that but once I have that correct and acurate info, is this how it is calculated?
Old Aug 27, 2008 | 07:38 PM
69LT1Bird's Avatar
You better recheck all of your measurements.
The stock pushrods are 7.400"
Base circle of aftermarket cams is usually .050" smaller
LS7 and LS1,LS2,LS3 etc lifters are all the same service part number
Assemble all of the part or at least one pushrod and rocker on each side and buy a pushrod checker and get the correct distance.
Odds are you won't need anything but stock length pushrods.
Old Aug 27, 2008 | 07:47 PM
vettenuts's Avatar
Not sure how you measured the lifter, but it might be worth a double check.
If you have an adjustable pushrod, take it apart and use the short end. Put the round end of the short half of the adjustable pushrod in the lifter cup and then measure from the roller to the top of the adjustable pushrod half where the threads are. Do this with both the stock and the LS7. I thought they were the same and would be surprised if they are not.
Old Aug 27, 2008 | 08:09 PM
Mike96z's Avatar
Someone else on Tech is the one who did the measurement and the LS7 lifter isnt actually longer, the cup is shallower, about .060" shallower.
The LS6 cam is a .050" diff so /2 = .025" on each side (19mm base circle)
Stock pushrods are 7.380, I thought they were 7.400" also but I was proven otherwise from GM.
Old Aug 27, 2008 | 08:37 PM
dz999's Avatar
I agree with using the pushrod checker on engine, it's the best way rather relying on supposably accurate dimensions. Each engine is a little different and the tolerances may add up combinations that make calculations come up short.
Old Aug 27, 2008 | 08:56 PM
00pooterSS's Avatar
7.380 Stock Pushrod
0.080 Plus Preload
By taking the factory measurments and figuring in the changes you have made that would make the preload stay the same as before since the pushrod is being pushed into the lifter just as much as before. I dont know the answer to your question but I would think you would be just right by doing that.
Old Aug 27, 2008 | 09:09 PM
Mike96z's Avatar
thanks, yea i think what i have as far as how to calculate will work good. ill check it all on the car though too.
Old Aug 28, 2008 | 03:47 PM
00pooterSS's Avatar
Can you let me know when you find out, I will be needing answers on this soon also.
Old Aug 28, 2008 | 04:00 PM
Mike96z's Avatar
cool ill let you know.
