ANY 500HP recipes???
Old Sep 4, 2008 | 04:51 PM
chrger528's Avatar
Default ANY 500HP recipes???
Im getting ready to do the setup on my car that i bought a month ago and im looking for 500 horses at the wheels.the car is an auto practically stock 2000 Z28 LS1.give me your idea of the build in these catagories, and if you can suggest something in between thats cool too.(keep in mind i do know about what i want im just doing this for suggestion purposes and keeping my options open if i find something that works a little better)heres the catagories:
Motor setup(internal and external):
transmission setup(auto and drivetrain):
tuning:
remember im looking to get AROUND 500hp at the wheels.a little over is cool.
thanks guys i appreciate hearing your responses!!
heres the car as a picture reference(soon to have the sunoco cowl hood on)
Old Sep 4, 2008 | 05:07 PM
WSsick's Avatar
Pat G made a thread about this EXACT topic. id link you to it, but that wouldnt teach you to use the search button. (its a really in depth thread if you read the whole thing)
speaking of the thread, can we make it a sticky now? i know tons of ppl have asked but why not?
Old Sep 4, 2008 | 05:08 PM
Mike2000Z28's Avatar
First reply in a while....
Research is key if you have a budget. Look at searching first and pick up some good ideas from the millions of other that have been there.
If you have some cash just order Trick Flows H/C 505hp package, LT (long tubes) headers, full cat-back, and intake is a start. I don't know where you are from so tuning is up in the air. Again look at the sponsor list for a shop in your area and take a road trip to see them.
How do you want your power, NA, juiced, blow, stuffed? Save up for the tranny soon after you figure out how you want to get to 500.
JDP's Avatar
JDP
there a kabillion setups that can get you that kind of power?
are you trying to stay with the stock shortblock? trying to stay all motor? do some reading and research, youll find a ton of setups. depends what route your looking to take
Old Sep 4, 2008 | 05:09 PM
ss.slp.ls1's Avatar
Default recepe
Here you go bro, great write-up!
https://ls1tech.com/forums/generation-iii-internal-engine/732392-recipe-500-rwhp-heads-cam.html
^^^can't spell (Title)
JDP's Avatar
JDP
haha, looks like we all are gave the same advice at the same time
Old Sep 4, 2008 | 09:40 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
500rwhp is a goal that isn't really easy to acheive. A lot of the supposed 500rwhp cars online get their from dyno tricks & tons of compression. We did dyno testing of different cylinder heads & camshafts side by side in the search for power across the board. Tell us about your vehicle & we can discuss a package that will work for you. I've made nearly 600 flywheel horsepower on the engine dyno with a stock bottom end. 500rwhp is possible, but to get that power honestly you'll have compromies...
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Sep 4, 2008 | 11:54 PM
99blancoSS's Avatar
It can be done, but it isn't inexpensive. The heads and cam choice are only part of the equation. The exhaust is very important. There are some TFS threads with people going over 500 rwhp as well as PatrickG doing it with some massaged 205's. BUT it's not cheap.
IMO better money spent would be on a 408 to acheive it a lot easier and have more power in a useable range. 500rwhp with a 346 vs 500 rwhp with a 408 is night and day to drive.
Old Sep 5, 2008 | 06:16 AM
AU N EGL's Avatar
Lets see:
HP
Reliability
Cost effective
Pick TWO
Old Sep 7, 2008 | 11:46 PM
chrger528's Avatar
I want to stay all motor and around 5 grand is alright for me to spend.the 408 was really high up on my list for choices so i might stick with that. I also saw the trickflow packages so i have some thinking to do.I have a couple performance tuning shops around here so tuning shouldnt be a big problem.reliability is a big factor,and i realize that power costs money,so compromise is ok with me.Gas here is freakin $4.20 a gallon here so this should be interesting.eventually soon itll be a weekend pounder not a daily driver so....
Old Sep 7, 2008 | 11:53 PM
GTOSE's Avatar
Now you have my attention
Originally Posted by AU N EGL
Lets see:
HP
Reliability
Cost effective
Pick TWO
Well said.
408 dumdumdum.
Then if you get bored you can throw on a pair of twins, make twice the power..
Old Sep 8, 2008 | 10:18 AM
Dragkid1917's Avatar
Trick flow 215's fully worked over, Big cam (MS4 or somthing allong those lines) some nice headers, probably 1-7/8. And a worked over FAST 92/92 setup. Underdrive pulley, Ewp, and some compression should get you there. Oh and if you plan on goin with a 12 bolt or have a big verter or big gears, it only robs your RWHP on the dyno, but will make it go faster (or be more reliable). In reality a fully built drivetrain with a 12 bolt and bigger verter, will rob enough h/p that it might not be able to graze the 500 mark, but on a six speed youd have made it. A dyno is just a tool, if my car made 490 RWHP with that drivetrain setup id be thrilled.
Old Sep 8, 2008 | 10:32 AM
https://ls1tech.com/forums/generation-iii-internal-engine/982895-ls1-camshaft-engine-dyno-comparision.html
Checkout this thread with our cam only dyno testing. We have several different 500hp sheets.
Jason
__________________
Jason
2005 Twin Turbo C6
Old Sep 8, 2008 | 10:51 AM
JScamaro's Avatar
To get 500 in an A4 you will need big cubes or a small power adder. For a more realistic goal on an A4 with 346 cubes I would shoot for 450 rwhp.
Old Sep 8, 2008 | 10:55 AM
crzytown69's Avatar
what he said
Old Sep 9, 2008 | 01:01 AM
KMS.1320's Avatar
Good post.
Also, you can call cartek, a sponsor on this site, they have 500+ rwhp stock cube cars running the number at the track. No matter where you decide to buy from, make sure you ask what times the customers with these packages are running. Gaining 30rwhp on a dyno just takes a few tricks.
