How does this sound?
Old Sep 9, 2008 | 03:38 PM
animuL's Avatar
Default How does this sound?
Mods in sig, add a MS3 cam on 113 LSA, with 918 Springs and Titanium retainers? Would I need Chromoly pushrods? Anything else I am missing? Do you think 400 whp and 11s n/a is doable?
Old Sep 9, 2008 | 03:48 PM
thunderstruck's Avatar
arent the 918 springs only good up to .600 ?
Old Sep 9, 2008 | 04:00 PM
TXZ28LS1's Avatar
yeah the 918's are only good up to .600 lift. i would go with some PRC springs or even some patriot gold springs i believe.
you should definitely make 400+ rwhp stock heads with that cam. and u should be in the 11's as well.
Old Sep 9, 2008 | 04:08 PM
animuL's Avatar
Texas-Speed.com says .625": http://www.texas-speed.com/shop/item...d=208&catid=48
This place says .625 as well: http://www.exoticperformanceplus.com....html?item=538 but CompCams website says .600.... either way I'm only going over by .009.
Old Sep 9, 2008 | 04:16 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
I always recommend going with a little extra spring! The dual spring kit is an easy way to ensure that if there is ever a spring problem (breakage), that you don't grenade the entire motor!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 9, 2008 | 05:24 PM
84ls1_transam's Avatar
Springs are rated for max lift. Anything over that, even if it is .009", that is too much.
Old Sep 9, 2008 | 05:31 PM
animuL's Avatar
I just read a post where a member called Comp and they said these springs are easily good for .620 lift, but they rate them at .600 so people like me who are trying to push it don't blow stuff up. Either way, you guys are probably right, spend an extra hundred bucks now or spend an extra $1500 bucks later...
Texas-Speed should probably clarify the info on their site tho... they even offer the MS3 with these springs as a package. Would hate to see someone blow their motor and blame it on them.
Now... what about those pushrods????
Old Sep 9, 2008 | 06:38 PM
MM98's Avatar
Definitely run dual springs & moly pushrods with that cam.. XER lobes are pretty aggressive & hard on the valvetrain.
Old Sep 9, 2008 | 07:07 PM
I agree.
