new edelbrock intake (at SEMA)?
My point being those short runners make it appear to be a topend intake that would be a dog down low where us street guys live.
I would love to be proven wrong but I guess it is a little late for me since I have already manned up and taken my my a$$ f*****g from FAST LOL
don't say heat soak...if you're that worried about it throw chunks of dry ice inside that huge open area between runs...
plus the way its built to let air flow under I doubt it gets any hotter than plastic, maybe even less
We have done that (with ice) burn through 30 lbs of ice and still a hot heat sink at the end of the day. You cna cool the intake off to 32 degrees, it will pull the heat right back into it from the cyl head. The less alum in intake, the cooler it stays
Plastic doesnt radiate heat. If your <7500 for 99% people I wouldnt even think about trying to reinvent the wheel, unless another composite wheel comes along. Been thru $6000 worth of intakes that tells me this.
Honestly I would like to see track times. Sure when your driving around town it'll get hot, but do you think that the air moving at 300+CFM sits in the manifold long enough to absorb a large amount of heat?
Again track times would be nice.
With a cast intake, isolated well the car previously went 9.69 in cold air. With another intake much more aluminum mass, similair runner length, SAME hp dyno'd back-back when bone cold, it was 20 hp or more down with some heat in the engine and a few tenths slower. A dyno pulls air thru intake in high gear just like going downtrack if its loaded right
Heat soaked intake cost us at least 2 tenths on a high 9 second car, naturally aspirated. When it was above 50-60 degrees ambient, there was no getting the engine down to temperature without hours
We dont live in theory, hence why i said weve tested $6000 worth of intakes. Real drag race stuff gets cooled down in a hurry between rounds and leave the starting line at like 130-140 degrees, 99.99% of people arent flushing their blocks with water out of a cooler between rounds
Ill stick with the plastic intake on my bucket, doesnt mind being hotlapped one bit.
and we all know heat is one of the worst things out their for a engine and trans-
theirs no turning back on that-
heat is a killer-
As I said before I do believe in heat soak it's not a theory it's fact. I would buy a composite intake over an aluminum one.
For me, the available cash is the deciding factor. It's much easier for me to justify spending 7-800 for 20hp(intake and tune) as it is to spend over 1k for 25hp.
You want cheap performance, youll spend $200 more than a LS6 and get a used fast. Or spend $450 more and get a new one. You WILL not make more average power than a intake packaged like that from 3500-6500 rpm, for what you are doing, period, unported. you will maybe pick up 2 tenths over LS6, and lose it all soon as engine gets over 150 degrees. Hello and welcome to the Weiand manifold 8 years ago guys.
06GTO, apparently you missed it as well? Ice bone COLD the two manifolds made EXACTLY the same HP. WITHI 2 HP EVERYWHERE. Get them HOT, and the one with a lot more mass of aluminum DROPPED 20 within 3-4 pulls, the other with open area under plenum maybe 5-8. Did the configuration of the intake change? No. Is it some kind of variable runner that opens up when the intake reaches 200 degrees?
The temperature changed only. Plastic manifold, it slows down hundreths, not tenths. Summary: Metal intake made with .5% hp ice cold, but lost up to 20-25 hot. Pretty A-B obvious controlled stuff thereIm not going to try any more, trying to say what weve seen over time testing with the 8K rpm hyd roller street/race stuff save from wasting money to find this but nevermind. "I dont think so" or checked it on
is somehow a more qualified answer here.Get that intake on any cam only LS1 or LS2 and well drive to the track and see how it works out, Ill bring mine with the plastic intake on
NJC, Ill see you on bullet
