Ls2 Sleeved VS a Ls7 blocks
Old Jan 27, 2009 | 08:23 PM
pmj341's Avatar
Default Ls2 Sleeved VS a Ls7 blocks
Which shortblock is better, stronger, for a 4.125 bore with a 4.0 stroke??
Old Jan 28, 2009 | 06:34 AM
ringram's Avatar
Done properly, Id say the sleeved block.
Old Jan 28, 2009 | 06:35 AM
pmj341's Avatar
Btt, is a ls2 sleeved better than a 427 ls7, and why??
Thanks
Old Jan 28, 2009 | 01:00 PM
blu byu EH's Avatar
This is a good question lets discusse this.
Old Jan 28, 2009 | 02:15 PM
davidws6's Avatar
Default Resleeved vs ls7
I ask the same questions to Steve @ RED. He said that he has many resleeved LS2's pushing 900hp without any issues.
Naturally the LS7 has the different grade aluminum and the stronger main caps. However he said that he has had to resleeve many ls7 blocks cause the stock sleeve took a dump.
Though might have been a bad tune ?
As you see in my sig. I have a resleeved ls2. I have not beaten it to the max but the tune is getting very close for a dyno pass n we'll go from there.
BTW, the Darton sleeves are also longer for a longer stroke !
Old Jan 28, 2009 | 06:09 PM
blu byu EH's Avatar
cool lets keep them coming. I'm subscribing now.
Old Jan 28, 2009 | 06:55 PM
ramairws6's Avatar
I just went out and got the best of both worlds.............a sleeved LS7 block from Steve at R.E.D.
Old Jan 29, 2009 | 05:28 AM
ringram's Avatar
Nice, I have a sleeved LS2 block from RED.
Old Jan 29, 2009 | 05:04 PM
blu byu EH's Avatar
Who is R.E.D.?
Old Jan 29, 2009 | 06:22 PM
ramairws6's Avatar
Race Engine Development outta CA. Steve is the only one I would let touch a sleeved block IMO.
Old Jan 29, 2009 | 07:00 PM
blu byu EH's Avatar
Talking
stop following me ramairws6
Old Jan 29, 2009 | 07:53 PM
ramairws6's Avatar
I was thinkin the same thing with you!
Old Jan 29, 2009 | 08:05 PM
blu byu EH's Avatar
Cool
Old Jan 29, 2009 | 08:07 PM
ramairws6's Avatar
I'm not that much better than you..................no need to hang from my sack in public!!
Old Jan 30, 2009 | 03:43 PM
pmj341's Avatar
After reading the comments, and HP that you have made with the Ls2 block, you have set my mind at ease.
I had ordered a Katech shortblock with 4.125 bore and 4.0 stroke, I just wanted peace
of mind.
I'll have it Monday, Lunati crank, Callies Compstar rods, Kateck 11.0 cr pistons.
I have an A6 so it will be a small cam and TFS 225 with 61cc Chambers.
Thanks for your input.
Old Jan 30, 2009 | 04:57 PM
blu byu EH's Avatar
Wink
sorry pmj341 ramairws6 know's he is slow so he likes to follow me around
Old Jan 30, 2009 | 05:44 PM
108dragon's Avatar
I'm doing the same kind of build for a blower application. I was told by many builders that the stock aluminum block sleeves are prone to cylinder deformation, especially under heavy boost and nitrous loads. So my question would be; What is the street reliability of the Darton sleeved block? I definately don't want the extra 100 or so pounds of an iron block over my front end.
Old Jan 30, 2009 | 09:35 PM
davidws6's Avatar
Default LS2 Sleeves
Contact Steve @ raceenginedevelopment.com
He'll answer all ur questions bout the Darton sleeves as he has worked with them to develop the sleeves.. He wanted to take me to Darton to show me around but I didn't have the time when I stopped in...
BTW, that's why I went with the resleeve to omit the extra 100lbs from the LSX block. Curb weight is about 3400 and it's almost a fully loaded 00 TA with a tube K member n tube A arms. ABS delete n a few other things..
Old Jan 30, 2009 | 11:39 PM
Gen414's Avatar
I just got my LS1 block today, and it will be getting the RED treatment soon enough....
Old Jan 31, 2009 | 01:52 AM
brokeLS1owner's Avatar
i was wondering roughly what it costs to build a resleeved ls2 short block, and with a good set of heads and intake what kinda power do they make na? sorry kind of a newb question just would like some info
