LS2/LS3 valley cover gasket and o-rings??
Exactly what the title says. Anybody on here know the part #'s for the cover seal/gasket or the o-rings that block off the DOD towers? This would be the non-DOD cover. Are these even available separately? The guy I'm helping bought this cover on Ebay. Unfortunately, it came without the gasket and seals, and I can't ever find anything online without the part#. LOL Ron
I also need this info, as I picked up the cover and bolts, no seals...
ALL Gen lll Engine's Gasket and Seals
#12574294 -Front Timing Cover Gasket
#12585673 -Front Timing Cover Crank Seal
#12574293 -Rear Cover Gasket
#89060436 -Rear Cover Main Seal
#12558760 -Valley Cover Gasket
#12558177 -Valley Cover Knock Sensor Seal SOLD AS A SINGLE
#12612045 -Valve Cover Gasket SOLD AS A SINGLE
#12577215 -Valve Cover Bolt with Groment SOLD AS A SINGLE
#12457116 -4.8L/5.3L GM Graphite Head Gasket SOLD AS A SINGLE
#12575329 -4.8L/5.3L GM MLS Head Gasket SOLD AS A SINGLE
#12498543 -LS1 5.7L GM Graphite Head Gasket 97-01 LS1/LS6 SOLD AS A SINGLE
#12498544 -LS1 5.3L HO/5.7L GM MLS Head gasket LS1 02-04/ 05-07 5.3L HO KIT W/ 2 HEAD GASKETS
#12589226 -LS1 5.3L HO/5.7L GM MLS Head gasket LS1 02-04/ 05-07 5.3L HO SOLD AS A SINGLE
#12589227 -6.0L GM MLS Head Gasket SAME for LQ4, LQ9, LS2 SOLD AS A SINGLE
#12582179 -LS7 GM MLS Head Gasket SOLD AS A SINGLE
#12610046 -LS3/L92 GM MLS Head Gasket SOLD AS A SINGLE
#12557752 -Oil Pump Pick up O ring w/o locator groove-GREEN in color WAS TOLD (C/K Trucks)
#12584922 -Oil Pump Pick up O ring w/ locator groove-RED in Color WAS TOLD (F and Y Cars)
#12482062 -Exahust Valve Seal SOLD AS A SINGLE
#12457652 -Exahust Valve Stem Seal Kit, 8 EXAHUST SEALS
#12482063 -Intake Valve Seal SOLD AS A SINGLE
#12533586 -Intake Valve Stem Seal Kit, 8 INTAKE SEALS
#12630223 -Water Pump Gasket SOLD AS A SINGLE
#89060413 -Truck Intake manifold Gaskets-W/ GREEN SEALS
#12617944 -Exhaust Manifold gasket for most V8 LS applications fits LS1, LS2, LS3, L76, and L92. SOLD AS A SINGLE
#12576221 -Exhaust Manifold gasket for the 2001 thru 2004 LS1 or LS6 Corvette. SOLD AS A SINGLE
#12587147 -Injector Seal Kit
#12551933 -Water tube crossover seal / block off seal SOLD AS A SINGLE
#12552542 -Throttle Body Seal
#12560251 -LS1-LS6 Intake gasket SOLD AS A SINGLE
#16194007 -Map Sensor Replacement Seal
Gasket and Seal Kits
#12499228 -LS Series Engine Cam Swap Installation KIT Includes front engine cover gasket, water pump gasket, intake manifold gaskets, valve cover gaskets, balancer bolt, and front seal.
#12499217 -LS1 5.7L Cylinder Head Installation Kit The kit includes two head gaskets, two valve cover gaskets, eight manifold gaskets, two exhaust manifold gaskets, two intake manifold-to-block seals, 16 cylinder head bolts, and 14 cylinder head bolt/screws.
#89017252 -5.3L/4.8L Complete Head gasket kit
#88894342 -LS1 Complete Head Gasket kit
#12533587 -LS1-LS6 Intake Manifold Complete Seal KIT
#12499234 -LS1/LS6 Complete Piston Ring Set Standard Bore Size 3.898
#12499235 -5.3L/4.8L Complete Piston Ring Set 99-05 Standard BoreSize 3.78
#12499236 -6.0L LQ4/LQ9 Complete Piston Ring Set 99-05 Standard Bore Size 4.00
Sensors
#12601822 -Replacement Knock Sensor Harness for Truck
#12102621 -Just the Knock Sensor Connector Pig Tail
#12589867 -Knock Sensor SOLD AS A SINGLE
#16040609 -2 BAR MAP sensor
#12580698 -2 Bar MAP LSX engines
#12223861 -3 Bar sensor
#12561211 -CAM sensor LS1 ALL GEN 3 BASED MOTORS
#12560228 -CRANK sensor LS1 ALL GEN 3 BASED MOTORS
#16212460 -Map Sensor
LS2 COILS HAVE 2 DESIGNS.
#12573190 -ROUND SHAPED COILS
#12570616 -SQUARE SHAPED COILS
Internals/ External Part Numbers
#17122490 -GM LS7 Roller lifter This Number is for a single Lifter, They are packaged in sets of 8
#12499225 -GM LS7 Lifter Pack of 16 to 7000 RPM This is the number for a package of 16
#11588791 -GM LS7 factory replacement rocker arm bolt.
#12579615 -GM LS7 Intake Rocker Arm
#12579617 -GM LS7 Exhaust Rocker Arm
#12578455 -GM LS7 Exhaust Valve
#12591644 -GM LS7 Intake Valve
#12578457 -GM LS7 Valve Spring
#12571251 -GM LS7 Camshaft Lift 0.593" INT / 0.590" EX Dur @ 0.050" 211 IN / 230 EX Centerline 116 INT 124 EX 120 LSA
#12568820 -GM Performance LS7 Crankshaft
#88958689 -GM High RPM Lifters Pack of 16 to 8000 RPM
#12586484 -Yellow Z06 Valve Spring Part number for 1 Spring
#12499224 -Yellow Z06 Valve Spring Set of 16 Springs
#10166344 -Retainer for all Factory springs SOLD AS A SINGLE
#10166345 -Valve Keeper SOLD AS A SINGLE SET FOR ONE VALVE
#12551162 -Lifter Guide, LS1/LS6 SOLD AS A SINGLE
#12595365 -Lifter Guide, LS2/LS7 SOLD AS A SINGLE
#12551163 -Lifter Guide Bolt SOLD AS A SINGLE
#12571595 -L92 Hydraulic Roller Two-Stage Valve Lifter SOLD AS A SINGLE
#17122490 -L92 Hydraulic Roller Two-Stage Valve Lifter SOLD AS A SINGLE
#12571596 -L92 Front Lifter Guide SOLD AS A SINGLE
#12571608 -L92 Rear Lifter Guide SOLD AS A SINGLE
#89018058 -L92 spark plug wires
#12584727 -L92 block
#12600767 -L92 Water pump
#89018166 -Truck Water Pump
#89018053 -LS1, LS2, LS6 Water Pump
#89018052 -LS2, LS3 and LS7 Corvette Water Pump Only
#12556437 -Camshaft retaining plate LS1, LS6
#12586482 -GM HD Timing Chain
#12576407 -cam gear LS1- Trucks
#12586481 -cam gear LS2
#12556582 -crank gear
#12565308 -02-04 LS6 Cam
#12571251 -05-07 LS7 Cam
#12553118 -LS1 LS2 Balancer for car aplications
#12576652 -TRUCK Balancer for 4.8 5.3 6.0
#12557840 -Balancer Bolt
#12560961 -Rocker Arm Bolt for 4.8's, 5.3's, LS1, LS6, LS2, L76, and L92. Does not fit the LS7!
#12586665 -OIL Pump
#12573460 -Rear Oil diverter W/Oring (Barbell)
#09427693 -Front of Block Oil Galley plug 4.8 5.3 6.0 LS1 LS2
#11609289 -Water Drain Plug side of block- 17MM Hex SOLD AS A SINGLE
#11588949 -Oil plug side of block - 10MM Hex SOLD AS A SINGLE
#12560272 -Main Cap Bolt SOLD AS A SINGLE
#12560273 -Main Cap Bolt W/Stud for windage tray SOLD AS A SINGLE
#12556127 -Cross Bolts though the block into the side's of the main caps SOLD AS A SINGLE
#12570326 -Cylinder Head Dowl Locator SOLD AS A SINGLE
#89060420 -Fuel Presure Regulator Truck Return style fuel systems
#88862586 -EOS GM's Engine Assemebly Lube Oil Additive 1 Quart
#12559353 -24x Reluctor wheel
#12586768 -58x Reluctor wheel
#12563918 -Truck Dipstick Tube 99-07
#12558684 -Truck Dipstick 99-01
#12610053 -Truck Dipstick 02-07
#12570788 -LS2 Dipstick
#15203890 -HD OIL Cooler Line set 99-04
#12570623 -Oil Filler Tube
#89017365 -Truck Intake 4.8, 5.3, 6.0
#88894339 -LS6 Intake Manifold KIT w/o EGR This kit includes the intake manifold, intake seal P/N 12560251, intake manifold gasket kit P/N 12533587, throttle body seal P/N 12552542, map sensor P/N 16212460, map sensor seal P/N 16194007.
#89017648 -LS2 Gen IV Intake Manifold
#12552344 -LS2/LS6 Intake Manifold Bolt SOLD AS A SINGLE
#12568002 -LS6 Valley Cover
#12573109 -LS6 Valley Cover pcv tube
#12554679 -Clip that hold the injectors to the fuel rail SOLD AS A SINGLE
#24500246 -Clip that holds the fuel regulator to the fuel rail SOLD AS A SINGLE
#12602448 -Standard Fly Wheel All LS1, LS2, LS3 engines To 4L60E/4L65E/4L70E
4L80E Conversion part numbers
#15000206 -Converter dust cover
#12551367 -6.0 Flexplate
#12563532 -Crank Spacer
#12553332 -Flexplate bolts SOLD AS A SINGLE (6 required)
#15198439 -4L80E Dipstick tube
#15183801 -4L80E Dipstick
#15013290 -4L80E Shift cable bracket at transmission
#11589040 -4L60/65/70/80/85E Toque converter bolt SOLD AS A SINGLE (6 required)
#15767858 -The tranny mount can be re-used because they use the same part number.
This is what I found for Head Bolts.... 99-03... NOT sure on 04-UP Individual #'s
OK THERE ARE 3 DIFFERENT SIZE BOLTS.
#12558840 -SHORT...YOU NEED 10 Total
#12560745 -MED... YOU NEED 4 Total
#11588291 -LONG... YOU NEED 16 Total
Those are the totals needed to do Both heads.
From experince, I have found it is More expensive to get them individual through the dealer, then it is to get a Head bolt Kit from some one...
#12498545 -Should be a Head bolt Kit for 97-03 ONE HEAD with the above 3 part numbers in it. YOU NEED 2 KITS
#17800568 -Should be a Head bolt Kit for 04-UP ONE HEAD Not Sure On Individual part numbers. YOU NEED 2 KITS
GM Remanufactured LongBlock's
#12491851 - 4.8 LR4
#12491854 - 5.3 LM7/L59
#12491357 - 6.0 LQ4
#12491860 - 6.0 LQ9
Sensors
#12586665 -OIL Pump
#12491851 - 4.8 LR4
#12491357 - 6.0 LQ4
#12491860 - 6.0 LQ9
This is the best I can do... Sort through:
http://www.performancetrucks.net/for...d.php?t=428941
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I saw your answer to my post in the conversions forum, and I think we're going to use your suggestion, but I'm still curious....did you use the DOD valley cover or a non-dod LS3 cover?? Ron
From my understanding, any engine not equipped with DOD did not have the towers drilled.
So why then did GM manufacture the non-DOD valley cover with those bosses cast into it directly over each DOD tower?
To the best of my knowledge, ALL of the GEN lV engines had the towers. This would be aluminum blocks with front mounted cam sensors, from around 2005. LS2's, some 5.3's in SUV's, Corvettes, etc. The ones I have seen have all had the towers drilled, but are not all DOD engines. The LS2 6.0 in my '34 coupe has the towers drilled but runs a larger cam and normal hydraulic roller lifters. It has the flat valley cover with the o-rings sealing off the towers. We have an aluminum block 5.3 Gen lV out of a 2005 GMC Envoy that has all the proper parts for DOD...solenoids, drilled towers,the DOD lifters and the valley cover with the passages to the solenoids, but, like **Geezer** mentioned in his thread, I don't think it was ever operational. Anyway, we've got the heads off, so we're going to change out the DOD parts, and since the o-rings are apparently unavailable, I'm going to tap the towers for 1/8" pipe plugs as suggested in the post by *LS1MCSS*
You wouldn't by chance have a picture of that would you?
I wouldn't have any trouble making the plate, but how did you handle the boss at the back for the oil pressure sender? Or, did you just seal it off and tap in at another location?
![](http://i388.photobucket.com/albums/oo326/lucky-77/IMG00057-20100118-1613.jpg)
Yes, the cover on the 6.0 in my '34 coupe is exactly like that, and the one my friend bought off Ebay is also like that. His came with no o-rings or perimeter gasket. The answer to your first question can be found in a thread titled *gm part numbers*. It's in the conversions forum and by now probably 2-3 pages back. Another guy on here was looking for the same info and John @ Scroggin gave this answer to **S10xGN**. If I've got it right...he says the perimeter gasket is available for around 20 bucks + S&H but the o-rings are on national back order with no shipping date, in other words NOT AVAILABLE. John still didn't give any part #'s. Hope this helps, Ron
I did get a local Auto Zone man to contact the Fel-Pro factory rep. At first he said the only way they could sell them was in a full set, somewhere north of $250.00. He called back later and said they actually did have them under this Fel-Pro #MS96871.
UPDATE!! I tried to find this number several places online last night with no luck. This morning, I called Fel-Pro's tech line (1-800-325-8886). The guy I spoke to said the number IS GOOD, but he had only received the info yesterday. He said the number is just now being released, but is not available yet. It looks like we are back to square one. Ron
