FAST 102 gains over ported LS3 intake in bolt-on 6.0L G8
There has been so much speculation as to whether the FAST 102 would gain any power over a ported LS3 intake on a 6.0-6.2L engine with a stock long block, I decided to conduct my own scientific test. By scientific, I mean that only the manifold gains or losses alone would be shown.
We started off with a 2009 Pontiac G8 with a 6.0L L76 engine with AFM/DOD, stock 90mm throttle body, American Racing 1 7/8" headers with dual cats, Vararam Cold Air Intake, ASP UD pulley, Yella Terra 1.85 rockers, and Comp 26918 beehive valve springs (so we could have better valve control above 6000 rpm). Stock cam, stock torque converter. All runs were same day, same dyno. The manifold swap was performed on the dyno.
The red run featured a Stage 2 ported LS3 intake manifold by an LS1Tech sponsor. This combo was super-tuned for best overall power. The blue run is with the FAST 102. It too was super-tuned. As you can see, even with the mildest of engines available with an L92/LS3 head, the FAST 102 intake manifold gains nicely over the most expertly ported factory intake. If you were to add significant airflow from a camshaft or increase cubes, the gains would only be larger. Remember, this is the smallest, mildest motor that come with rectangular port heads.
For those who can't read the dyno sheet, the ported intake made 389.3rwhp/387.6rwtq. The FAST 102 made 393.7rwhp/390.6rwtq. Although the peak gains were only 4.4/4.0, the gains at other rpm were much higher.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Patrick Patrick, say it isn't so. Say this isn't ANOTHER Fast 102 intake comparison using a 90mm tb??
I was sooooooooo excited that it was you posting the comparison but in the end, this comparison is much like the others, meaning not performed with the tb it was designed to work with.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I was sooooooooo excited that it was you posting the comparison but in the end, this comparison is much like the others, meaning not performed with the tb it was designed to work with.![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
__________________
On another positive note, I've seen my fuel economy increase 1mpg above the factory intake. It took a 1mpg drop with the ported intake vs stock, but the FAST got it up 2 mpg over the ported intake (hence the 1 mpg gain over stock). I know these are inconsequential gains for many on this board, but for a daily driver, any time you can gain some power and get better fuel economy, that's good news.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
__________________
Depends on whether I have a headwind or tailwind. In calm winds, I'm getting 26-27mpg at 70-75mph. A tail wind raises it closer to 29 and a head wind drops it closer to 24 mpg. The mileage varies more in 4 cylinder mode because it doesn't make near the power as all 8. A 20mph head wind really taxes the motor in 4 cylinder mode compared to when it's running on all 8.
__________________
Season hasn't even started yet.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
You really think those nice gains you're talking about is worth the $900+ for that inake on that combo? I know it's your money that was spent, you made that very clear but perhaps some members who want to get the most hp per dollar would disagree that the intake gains "nicely" considering what it costs. I know I do.
I appreciate most of the threads and research you do and post up one here as I'm sure many other members do also, it's good for a read. I personally have not applied any of the info you have provided over the years on my own car but that's irrelavant.
Thanks for bolting an intake on and posting the dyno graph Patrick.
You're a pioneer.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Keep in mind, the dyno overlay is of FAST 102 gains over what some consider the finest hand ported factory intake. If you look at the gains vs a stock LS3 intake, the gap widens further at higher rpm. The FAST 102 is in red and the stock unported intake is in blue. There's over a 20rwhp gain at 6200 rpm. Just think how much it would gain with a cam bigger than my 200/208 .479/.478 116LSA stock cam. ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
__________________
Good test and interesting results indeed. I fell partly responsible for setting the fires that led to this I have to say.
That said Its still very pricey $per/hp ratio to me and not convincing enough for my build to require one at this time. It still seems clear that concerning L92 heads and FAST intake its a case of
"the bigger the cubes, the bigger the rewards"
So when i build bigger cubes in a couple years I'll look into it then. $1000.00 buys a lot of stroker parts
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
So when i build bigger cubes in a couple years I'll look into it then. $1000.00 buys a lot of stroker parts![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Remember, the old FAST 90 only made nominal gains when bolted up to a stock LS1 with stock LS1 heads and stock LS1 cam. Of course, few will deny how essential a power producing component the FAST 90 was for the LS1s once you added better heads and larger cam.
For the 6.0L and 6.2L engines with L92/LS3 heads, we already have really good heads, we just need better cams to make big power gains. When you get to this point, the FAST 102 LSXR will again be a must-have component for staying ahead of the competition.
__________________
Pat,
Long time no talk to!
Just stumbled across this thread and have to say good job as always documenting the info which helps many of the members of this board make some decisions of their own.
The new FAST, as you mentioned, would likely show better gains on a more aggressive package with higher flowing reworked heads. I also think there are a few more ponies to be found with some porting of that piece (
), but honestly even that work would be somewhat wasted on a mild package with that head and manifold configuration.
FWIW, I have reworked a handful of the cathedral 102's lately and they need/require more work than the rect port L92 or LS7 seem to require to be optimized....meaning there are more gains to be had from doing the porting to the cathedral version of the FAST than the square port versions although a few of my LS7 guys have seen 20+ over their OEM intakes which is impressive IMO (without the huge TB btw).
I will post some pics soon of a cathedral 102 R&D piece I have been testing (bolted to our new 245 heads) with some before and after pics of the intake. Quite a bit of plastic shards when Im done with one of those but Im actually seeing 325 CFM net at the cylinder when bolted in front of a new 245 AFR that flows in the mid 350's (killer cathedral #'s obviously).....and thats very good for a long runner bolt on design with a common plenum. It just needs a good bit of work to get there (even getting over 300 CFM net is an accomplishment here guys).
Down the road when the power bug in the G8 keeps biting lets get together on that manifold!
-Tony
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
-Tony
![](http://i307.photobucket.com/albums/nn283/Flowizard/2006_1112DougMarshall0002.jpg)
