LS9 valve covers
Old May 1, 2011 | 06:32 PM
  #121
cookba's Avatar
if you guys are getting an extra valve cover and pulling the coils off, pm me cause i would like just a passenger and drivers side valve cover.
Old May 4, 2011 | 09:27 PM
  #122
Paul Bell's Avatar
That's MISTER MODERATOR
I really like these valve covers BUT I even more like easily removing all the coils as one set to reach the right side spark plugs. And my heat-sinked truck coils (which I really like) won't fit them.
Old Nov 29, 2011 | 12:42 AM
  #123
Miles.'s Avatar
Are these still available? I looked on SDparts.com and can't find anything.
Old Nov 30, 2011 | 10:38 AM
  #124
cookba's Avatar
send them a PM
Old Nov 30, 2011 | 12:10 PM
  #125
RAMPANT's Avatar
The Holleys are nice too, mine showed up today and have the same coil pack layout.
Old Jun 23, 2013 | 11:51 AM
  #126
samckitt's Avatar
Bringing back an old thread. Why do they only come with 3 coils per side? Weird.
Originally Posted by Beau@SDPC
Figured I would make a quick update on this since I have had a few PMs regarding the LS9 Covers, and kind of pick up where John left off.
Here is current pricing on the LS9 Valve Cover Conversion:
RH & LH Valve Covers - $132.49 each (They come will 3 coils per side)
Oil Filler Cap & O-Ring - $7.49
2 Coils - $68.75 each ($137.50)
4 Bolts - $3.05 each ($12.20)
RH & LH Coil Harness - $29.49 each ($58.98)
$481.15 + shipping with Coils/Harnesses. (LS1 Conversion)
$272.47 + shipping without Coils/Harnesses.
$463.94 + shipping with 3 Covers, Filler Cap, & Harnesses (LS1 Conversion)
$404.96 + ^ w/o Harnesses
LS1 Coils/Harness will not fit. LS2/3/7/9/Truck will.
Must change to LS9 Oil Fill Cap.
I have these in stock ready to ship!!
Old Jun 23, 2013 | 11:56 AM
  #127
samckitt's Avatar
Also, if any of you have bought the 3rd cover for the coils & are selling bare covers. Let me know, I'm looking for both sides.
Old Jun 24, 2013 | 03:53 PM
  #128
Beau@SDPC's Avatar
LS1Tech Sponsor
We honestly do not know why GM sells them this way. Wish I had a better answer for ya.
Old Jun 24, 2013 | 08:33 PM
  #129
samckitt's Avatar
Which part number is the one that has the oil fill hole?
Old Jun 28, 2013 | 01:56 PM
  #130
victorf's Avatar
IMO, OEM or aftermarket valve covers having coil mount cast on one piece is simplicity in packaging from the manufacturing stand point. Certainly not having the best interest in component longevity associated with direct heat conduction.
So I choose to do it these way started with OEM covers:
Engine heat is free to radiate from the covers and the base for the coil relocation brackets are on non metallic base to avoid direct heat conduction. Wiring harness for both coil/fuel injection are isolated within marine grade split loom to protect from engine heat as well.
That is just my interpretation derived from my own opinions.
Old Jun 28, 2013 | 07:33 PM
  #131
Paul Bell's Avatar
While your work looks very good and the level of craftsmanship is obvious, I can't fathom any gains from keeping the coils cooler. Due to heat radiated from the engine and the heat blown onto the engine from the radiator, I doubt the coils are actually any cooler. These coils are designed to operate at the high temperature of the engine bay.
Other makers (as well as GM in OHC engines) use the COP setup where the coils are pressed into the valve covers and certainly absorb even more heat without issue.
The only way to make ignition coils perform "better" is swapping them to higher output coils and a tune to take advantage of them. And these gains have been hit or miss.
Old Jun 29, 2013 | 02:53 PM
  #132
victorf's Avatar
Lets just say that there is no increase in performance.
What does engine heat do to plastic, wiring and wiring connectors in the long term? Ever break off connector locks while disconnecting?
I did not do a before and after temperature check with any instrument, but touching by hand while engine is already hot is doable as compared to before relocation. Cool down after is certainly takes a whole lot less time.
Knowing the simple fact that the same components are no longer exposed to direct heat conduction, insulated as well as isolated while in the some hostile environment is enough to satisfy me.
Manufacturers will streamline and simplify component packaging anyway they can to save a buck and increase their profit margin. But when I see flaws, then I will do what I can to improve any given situation.
But to each his own.
Old Jul 1, 2013 | 07:55 PM
  #133
samckitt's Avatar
Well I bought the one with the oil fill hole from my local dealer thinking it would help my issue, it didn't. So I have it for sale, $140 shipped.
Old Oct 5, 2013 | 02:59 AM
  #134
2QuikTA's Avatar
Beau, is the LS1 conversion pricing still the same?
Old Nov 7, 2014 | 05:17 PM
  #135
Spectre86's Avatar
Originally Posted by t/a98
Yea but don't buy two coils and bolts separately. Just buy a third valve cover. You'll save money and could possibly sell the left over coil and cover for a profit.
Not sure if I missed it, but do these come with the valve cover bolts or gaskets?
Old Aug 11, 2016 | 08:59 AM
  #136
samckitt's Avatar
Originally Posted by 04BlackSilverado
Google is your Friend
Bringing back an old thread. But what is this kit pictured here? Is this for adding a supercharger? Anyone have the PNs for the vent tubes?
Thanks
Old Aug 19, 2016 | 03:53 AM
  #137
Jontall's Avatar
You can buy just the valve covers (no coils): LH- GM # 12637686, RH- GM # 12637688
Old Aug 24, 2016 | 08:02 AM
  #138
samckitt's Avatar
What is that pictured above, is that a kit that can be purchased, or just for display?
Old Aug 25, 2016 | 05:27 AM
  #139
Jontall's Avatar
That's how they lay-out the parts for engine builds in GM's engine assembly plant. It can't be purchased like that, but can be ordered separately from a dealer.
Old Aug 25, 2016 | 05:37 AM
  #140
Jontall's Avatar
Thanks
(Vent tubes) PIPE. Engine Coolant By - Pass.:
PIPE,ENG COOL AIR BL - RH. GM part # 12606242
PIPE,ENG COOL AIR BL - LH. GM part # 12606243
BOLT. Engine Coolant By (2 required- bolts) GM part # 11588715
http://www.wholesalegmpartsonline.co...ukey_make=1024
