broke a bolt in the head :(
long story short my torque wrench is a piece of **** and i broke #10 intake manifold bolt in the head. if i can't get it out, can i run it for a while with one broken bolt? i know i'll have a vacuum leak, but i was curious if anyone else has just run it till they put different heads on.
I would pull the intake off and try work the bolt out with a pick. Once the bolt breaks the tension is taken off the threads and you can usually turn them out though it may take awhile.
UNDER PRESSURE MOD
I did that when I installed my FAST the first time. Actually, I did it twice. Each time, in succession, I was able to remove the intake and remove the bolt by hand pretty easily. I quickly learned how to do 1/8 turns on each bolt and it took about 10 passes to get it fully seated and tight.
pulled the intake up and whoops the bolts broke off far down into the hole, i'll see how it runs with 9 bolts holding it in place.
btw mods could you move this into Generation III External Engine please
not too much of a leak lol it only idles at 1600 when cold and until i drive it around the lowest it'll go is 850-900, it'd be great if i had a cam i could drive it and not worry about the idle being way to low for the cam
the bolt is in the head so i'm gonna have a buddy look at it and see if we can get it out with the head still in the car, if not i'll be throwing on some other heads with a LS6 cam
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
and anytime the mods wanna move this thread into the gen III section would be nice . . . unless you wanna give me mod powers so i can get it done in less than 6 days lol
