LS3 vs LS7 intake
Old Dec 16, 2010 | 05:35 PM
blackey's Avatar
Default LS3 vs LS7 intake
Both Trickfow and PRC will have heads out soon that flow the same but can be ordered with LS3 or LS7 intake configurations.
Which intake is better and by how much? (ignoring the Fast versions for now)
Both seem to use LS7 rockers which I believe are 1.8. Does anyone make 1.7 LS7 rockers?
Old Dec 16, 2010 | 05:52 PM
Jenson's Avatar
The LS7 intake is much better than the LS3. It very much resembles a Fast inside.
Old Dec 16, 2010 | 06:07 PM
396D1SS's Avatar
Texas speed did a test. I believe the ported ls3 did better then the fast 102.
I am sure someone has flowed both of them and has numbers
Old Dec 16, 2010 | 06:49 PM
litle88's Avatar
I would also like to see these tests but on a stroker ls3.
Old Dec 16, 2010 | 07:09 PM
hitmanws6's Avatar
That was not the test, the tested a FAST 102 against the LS7. The gains werent earth shattering, but they were there across the powerband. And a ported LS3 will never do better than a 102.
Old Dec 16, 2010 | 11:52 PM
briancb1's Avatar
Really? Some people report a power loss with the 102...
The Fast Manifolds are hands down top dog on LS1/2/6's and it seems shakey on some LS3/7's if they work or not. It seems combo dependant.
Old Dec 17, 2010 | 02:03 AM
hitmanws6's Avatar
the LS3/7 intakes are very good out of the box, but the 102 will still outperform them on a stock motor, even if they are ported
Old Dec 17, 2010 | 08:36 AM
ramairws6's Avatar
Listen to this guy, he knows what he's talking about....
Old Dec 17, 2010 | 09:55 AM
Jenson's Avatar
So you think an LS3 and LS7 intake are essentially same? Just looking at the runners on the inside of the LS7 leads me to believe it will perform much better, and add to that it has a bigger plenum and shorter runner. IMO the LS7 is better for a heads/cam combo
Old Dec 17, 2010 | 12:26 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
i have done my own testing on my own car, customers cars and one for Powertv all one my dyno that is where i get my info from.... where do you get your?
Old Dec 17, 2010 | 01:24 PM
blackey's Avatar
LS3 vs LS7 stock intakes
Lets not turn this into is a FAST intake better on the LS3/LS7 debate...
Old Dec 17, 2010 | 01:33 PM
hitmanws6's Avatar
I just report what i see. Pat G gained power with the 102 over a ported LS3 and Texas Speed gained over a ported LS7 on a stroker.
Old Dec 17, 2010 | 02:45 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
i see.... so that is your factual basis.... anyone with a ls1tech account that knows how to use the search function could do that... no offense
Old Dec 17, 2010 | 03:52 PM
good2go's Avatar
What were your results?
Old Dec 18, 2010 | 06:14 AM
hitmanws6's Avatar
None taken, I simply pointed out results from reputable shops that have tested the intakes. I don't claim to be an expert, I just pass on what I find Ryne.
Old Dec 18, 2010 | 08:01 AM
SweetS10V8's Avatar
The question really is, what size is the engine this is going on. The runner design of an LS7 intake is for a larger ci, and will loose torque if put on a small ci engine.
Plus the head ports are totally different, I highly doubt they "flow the same".
Old Dec 18, 2010 | 08:48 AM
ramairws6's Avatar
https://ls1tech.com/forums/dynamomet...e-results.html
