102mm PTM Throttle Body issue
Okay so I have had this throttle body on my car for not even a month. Brand new in the factory sealed box. Now I have started to experience issues of it getting caught up. The first thing I checked was to see if maybe the blade was loose and that wasn't the case. Then I went to check to see if maybe there was some carbon build up. Nothing there. After that I replaced the return spring and that didn't work.
I am wondering if anyone has experienced this issue and what was done to fix the problem? Or is this one of those cases that I will need to get in contact with the place I purchased it from? Or do I need to get rid of it and purchase a different brand throttle body?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
lol I think that is what I'm gonna do. Unless someone from TSP can chime in on this or any other vendor who sells PTM throttle body's. Sad part of all this is that I have been trying to break in my motor and this issue is really holding me back from break in time. At this point I have barely put 100 miles on the new motor and it makes me nervous to drive the car in fear that its gonna get hung up and cause the rpm's to sky rocket. It did this one time and I turned the car off asap. I got out of the car and had to manually put the throttle body in place.
I have a FAST 90mm that used to hang up. I disassembled it and noticed that the shaft was bent. It looks like someone pushed too hard on the screws when they were installing the tb blade and bent the shaft. It was only noticeable when I laid the shaft on a flat surface. When you have it apart, you can get another wind on the spring to see if that helps, also. I've run secondary springs as a last resort. Good luck.
LS1Tech Premium Sponsor
Definitely call us and we'll get it straightened out!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The OP didn't bash the product, simply posted a problem to see if its common, and if its easily fixable. Nothing wrong with this post what-so-ever.
Secondly, what kind of gains do people see when going to larger/ported throttle bodies? The prices has always held me back. But I'm running out of ways to get more power...
Anyone do back to back tests?
The gains or larger a throttle body will depend on your other mods of course.
