OK, ready to get hammered for even asking the ?, but can you reuse intake/tb gaskets?
Usually I just replace all gaskets, but on my 2010 engine w/only 3k miles the intake manifold gasket and the throttle body look pretty much like a rubber that you might be able to reuse like a rubber valve cover gasket. And they're moderately expensive. Does anybody reuse these when changing intakes or are they always replaced? If I need to spend $$ here I will, but if not needed these still look in great shape...
TIA
TIA
TIA
TIA
You can re-use rubber gaskets as long as they are in good condition. If they are flat then replace them. I never reuse the intake ones since they are relatively cheap and take a while to get to, but the throttle body one is easy to get to and is a lot less likely to flatten so I will re-use those.
