missing nut MSD intake?
Old Jan 14, 2018 | 06:13 AM
lowcountry's Avatar
From: Grew up in Charleston, SC live in Moncure, NC
Default missing nut MSD intake?
The attached photo shows the inside of my LS7 MSD intake towards the rear. Is there supposed to be a nut on that stud? There is one on the front side. It is hard to tell how it's put together without taking it apart.
thanks.
Old Jan 14, 2018 | 08:41 AM
Double06's Avatar
Push it and see if it moves. On the MSD they have some threaded inserts and this might be one of them. I presume that is the one that holds all the intake tubes together. I would check on line for photos there are a few with the top taken off and you can see this area.
Old Jan 14, 2018 | 10:52 AM
lowcountry's Avatar
Doesn't move and yes it appears to hold all the intake tubes together.
Old Jan 14, 2018 | 06:34 PM
Mine has a nut on it there. Make sure to use nylocks. I don’t think it’s very tight, it just holds the runners from moving basically. You don’t want a loose nut rattling around in there!
Old Jan 15, 2018 | 06:20 AM
lowcountry's Avatar
Just to clarify, we're talking about the rear stud. Mine has one on the front.
For sure about the lose nut!
thanks for posting
Old Jan 15, 2018 | 11:55 AM
My truck has a loose nut right behind the steering wheel! lol
Old Jan 15, 2018 | 01:24 PM
brandon6.0's Avatar
Definately supposed to have a nut. U can see the loc tight on the threads
Old Jan 15, 2018 | 08:52 PM
Yes, there’s a nut on both ends, front and back. And behind the wheel here as well...
Old Jan 16, 2018 | 07:11 AM
Double06's Avatar
See if the nut is hiding somewhere In the plenum there - don't want that going anywhere.
Old Jan 17, 2018 | 01:49 AM
brandon6.0's Avatar
^^ yes for sure. had a buddy suck up a bolt and a but connector on 2 diff motors from the intake. Intake was purchased used and never really checked it.
