Gen4 6.0 swap big power loss!
This might be a long read. Kinda hard to explain. I have a customers obs ls swap. We swapped this 5yrs ago with a built 60e, 4.8 btr stg4 truck cam, tbss intake etc. My tuning. Been tuning close to 15 yrs. Truck ran great! Plenty of power pulled to 7k, great power everywhere for a 4.8 couldn't beat it for a simple combo!
this yr we went a diff route. Gen4 6.0 square port heads, tick stg3 sns cam, holley high ram, built 80e etc. Truck is down on alot of power. Revs clean at idle and feels strong but down the rd it's a dog. Weak through out the pull and gets to 5500rpm it noses over hard. I can short shift it and it will start pulling again. Just doesn't run like a well built 6.0 should
Lil more on the combo.
4.10 posi
80e FTI billet 3800
-6 braided fuel lines with aeromotive regulator
longtubes to 2.25 true duals and flow 40s
4" Cai
92mm tb with high ram 36# flex inj.
etc.
I disconnected the Cai and ran it just open tb without any luck. I think it's either blowing through the converter or exhaust restriction. Idc is showing around 80% at wot. I even swing timing to 29* to see with no change from 24*. We do run a lingenfelter 58 to 24 box on this combo. Thoughts?
4.10 posi
80e FTI billet 3800
4" Cai
etc.
That exhaust is pretty small and with the addition of mufflers I would imagine it is choking your high flowing engine.
Easiest way to troubleshoot would be disconnect the exhaust the the headers and clamp some 1' extensions on there and go for a rip.
Coming way out of left field here, but as far as it being a dog on the road could that partly have to do with the 80e’s gear ratios?
Imo no. I've built plenty of 80e combos and nothing similar to this one. My stock 06 5.3 crew cab will walk the dog on this truck currently. I've done over 30+ ls swaps diff combos trannies etc. Over the yrs. I actually assembled engine and built the trans myself. I build trannies daily. It puzzles the he'll out of me. This truck had this exhaust on it. I would have had 3" true duals with magnaflows imo. I was working with what he had.
I think it's exhaust tho. Flowmaster are known for comming apart inside. Ls don't like restrictions anyways. I'll try exhaust tom throw something together and see if it picks up some power.
The following users liked this post:
Y2K_Frenzy (02-07-2024)
G Atsma (02-07-2024)
Which fuel pump are you running? As said just above, it might be starving for fuel.
As mentioned:
"longtubes to 2.25 true duals and flow 40s".
The pipe size and the "blowmasters are where I'd start.
G Atsma (02-11-2024)
The following 2 users liked this post by Old Buzzard:
G Atsma (03-04-2024), Tommy42088 (03-04-2024)
LS3 does get 42# injectors.
You are not running out of injector with the 36lbs, that thing isn't making that much power.
If the low fuel pressure is the problem, which it's a good possibility, I would have thought it would have been seen on the WB02. Hell, you probably could see it on the narrowbands too.
