LPE 100 mm MAF
Old Sep 26, 2006 | 09:35 PM
Bink's Avatar
Default LPE 100 mm MAF
Anyone used this on an NA application??
Positive results??
non-sponsor link removed by Admin
Old Sep 27, 2006 | 08:33 AM
firefighter's Avatar
I thought that that was for Forced Induction apps. Some guys talked about it in the FI forums here and perf trucks.
Old Sep 27, 2006 | 01:18 PM
Bink's Avatar
FI yes.
But, I was wondering if the 85 mm MAF was a restriction on the bigger bore na setups - seems like it would be with the heads available (360 -380ish)??
Old Sep 27, 2006 | 02:20 PM
RedHardSupra's Avatar
HumpinSS tested 85mm MAF vs straight pipe on his 430rwhp car, and dyno showed less than 0.5hp difference throughout the entire rev range, so i say it's not a bottleneck.
Old Sep 27, 2006 | 07:27 PM
Bink's Avatar
Thanks, man!
I was thinking more along the lines of total airflow through the enlarged intake (4" and 100mm cs MAF) feeding a 550-600 rwhp biggie sized block.
Old Sep 28, 2006 | 01:46 AM
Nate_Taufer's Avatar
I went with a straight piece of pipe over the stock maf and gained 7 rwhp on the same dyno but different day. I am around 420 rwhp cam only. My butt dyno couldn't tell the difference.
Nate
Old Oct 1, 2006 | 08:53 PM
John B's Avatar
Moderator
Positive results??
I just ordered one for my LS7 to replace the 85mm MAF so we'll see!
Old Oct 1, 2006 | 09:34 PM
Pro Mouse's Avatar
Thumbs up
Interesting, please let know
Old Oct 2, 2006 | 09:37 AM
Katech_Jason's Avatar
LS1TECH Sponsor
I'm doing an A-B test on the chassis dyno soon. I'll post the results.
Old Oct 2, 2006 | 12:44 PM
slt200mph's Avatar
Hay Jason it was nice to finally meet you .. you guys were "good neighbors" at the Petit Le Mans.. that was a very nice car and you had some nice parts too ...
Steve
Old Oct 2, 2006 | 01:54 PM
LS1TECH Sponsor
Steve
Thanks, you too.
Old Oct 2, 2006 | 03:05 PM
Pro Mouse's Avatar
Thumbs up
That would be sweet Jason ,Thanks
Old Oct 2, 2006 | 05:44 PM
98blackSS's Avatar
I'm very interested to hear what the results are from both John and Jason. I'm on the fence on ordering one for the LS7..
Old Oct 2, 2006 | 06:26 PM
Bink's Avatar
Thanks John.=!! Let us know.
Old Oct 2, 2006 | 09:37 PM
John B's Avatar
Moderator
Will do since I will also be doing a back to back test. In addition, I will be trying out one of Jeremy Formato's ported LS7 intakes (just sent him a new core Friday). I will also be doing some dyno tuning to see if I can crack 510-520RWHP on a stock motor since I haven't done anything with my timing or A/F curves yet. If this doesn't get it then I might also step up to the 96mm TB!
Old Oct 2, 2006 | 10:55 PM
D Rock's Avatar
being this is a 100mm for a NA application, is 105mm throttle body too much for a high performance NA application?
Old Oct 3, 2006 | 10:26 AM
99Fbody99's Avatar
For what its worth the LPE MAf is nothing more than a current C6 meter element stuff into an aluminum housing.
Dave
Old Oct 3, 2006 | 11:31 AM
Bink's Avatar
Dave
The C6 Maf is 100 mm??
Old Oct 3, 2006 | 11:33 AM
Bink's Avatar
Cool! - then we'll have yours and John's results
Old Oct 3, 2006 | 01:15 PM
LS1TECH Sponsor
Dave
No it's not. It looks more like a GTP MAF.
