anyone make a 2" race style header??
Old Apr 15, 2007 | 07:34 PM
Noyzee's Avatar
8 second mod
Question anyone make a 2" race style header??
for the ls style f-body?
no y-pipe ect, just need a header. anyone?
Old Apr 16, 2007 | 08:22 PM
JL ws-6's Avatar
Race your car!
if you're talking about the primary, I don't think so. 1 78 stepped to 2 inch is the biggest I have ever found anywhere. If you are going with the tall deck version of that block you're gonna have to have the headers made anyway because they will be sitting up alot higher.
You are probably gonna want a 4 inch collector too if you are gonna go as big as I suspect you are planning.
Old Apr 16, 2007 | 08:40 PM
02SOMWS6's Avatar
[QUOTE=Noyzee]for the ls style f-body?
no y-pipe ect, just need a header. anyone? [/QUOT
Give Kooks a call. If anyone can do it they can. They do alot of custom of a kind stuff
Old Apr 16, 2007 | 08:43 PM
JL ws-6's Avatar
Race your car!
ARH too if it comes to that Brad.
Old Apr 17, 2007 | 11:10 AM
Noyzee's Avatar
8 second mod
yhea, i think im going to stick with what i have for now, and upgrade next year when i go solid roller ect.
ps, im not going very big
Old Apr 17, 2007 | 11:15 AM
JL ws-6's Avatar
Race your car!
I'm actually surprised you're not gonna do the solid roller now, with the block already apart and going with that lsx block, now would be the time to do it.
I kinda wish I had done that right up front... when the motor has to come apart and get re-ringed and new bearings, it's probably gonna get converted to solid roller, even if the cam doesn't get huge, just the stability, and ability to go way bigger with it later will make it worth it.
Old Apr 17, 2007 | 11:31 AM
Noyzee's Avatar
8 second mod
yhea, the problem is i dont have the $|$$ to spend the 2500 on solid roler. for me its easy to go solid roller. i can probably swap everything in a day. just have to come up with the $$$
Old Apr 17, 2007 | 11:37 AM
JL ws-6's Avatar
Race your car!
exactly the reason I didn't do it up front as well. Hopefully by the time I need to rering and put in bearings... I'll have the $ to do it. I hope.
Old Apr 17, 2007 | 01:18 PM
MarylandSpeed's Avatar
Kooks makes one. If you need help, give us a call at 443-730-9428. We have great pricing on Kooks.
Old Apr 27, 2007 | 07:59 AM
ATVracr's Avatar
They make a strait 2" primary with no step?
Old Apr 27, 2007 | 08:37 AM
Noyzee's Avatar
8 second mod
i called kooks direct and they said only the 1 7/8 step to 2"
i ordered them yesterday
Old May 4, 2007 | 08:25 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I was going to say probably Lemon makes crazy set ups like that
Old May 4, 2007 | 09:39 AM
ATVracr's Avatar
Somone will start making them soon with all these big motors being built.
Old May 4, 2007 | 11:21 AM
JL ws-6's Avatar
Race your car!
really 427+ ci at more then 13.5 to 1 compression, anything that large or bigger (427 being about as small as I think anyone will go with an lsx/world setup) would probably benefit from 2 inch primarys. nitrous and supercharged applications, with 450+ ci I couls almost see needing even more then that.... but then you run into the space constraits of the engine bay. Hell the tall deck setup is gonna be intresting in an f body engine bay.
Old May 4, 2007 | 01:04 PM
71CamaroLS1's Avatar
Not to start a big controversy or anything, but I seriously wonder whether anything over 1.875 is going to make much difference, given that the exhaust valve on the LS motors is no bigger than about 1.6. Larger tube diameters reduce the intensity of the scavenging pulse in exchange for greater flow capacity - but if your exhaust isn't flowing enough to take advantage of the greater flow capacity, the reduction in scavenging intensity will cost you power. Formulas that say "so much tube dia for so much HP" are often approximations based on engines (e.g. BB Chevy) with larger exhaust port cross sections relative to max horsepower.
Keep in mind that 1400 HP, 10,000 RPM pro-stock motors are using, I believe, 2 3/8 primaries (and about 1.9 exhaust valves).
It's actually quite difficult to construct real world tests to prove this one way or another, because there are so many variables - exhaust valve open point, primary length, collector design - and some of those variables are interdependent. For instance, changing tube diameter also changes optimum primary length, which in turn is dependent on exhaust valve opening point, etc. So engine A makes more power with the bigger header, and engine B loses power, and neither proves a general point.
One thing is for sure: the LG motorsports guys have proven that you can make 600+ RWHP using 1 3/4 primaries, which just goes to show that the combo is everything.
