what am i doing wrong help asap
Unless you have so much leakage you can't keep the bore "full" of air to maintain the valves to stay in place.
Also, when you have your engine on TDC take the breaker bar off cuz it will want to rotate the engine and you don't want that thing flying around.
I have a soft grip Snap-on wratchet and the rubberized handle works well. Couple taps and they break freeIt doesnt take much and your not trying to hammer them.
Put the tool on then add slight tension then tap the top of the retainer gently.
