What Pistons Should I get??
With a flat top piston (wiseco) you would maintain the 11:1 compression
let me know if you have any questions
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
in the end, cylinder pressure is cylinder pressure so you can go either way
i still think lower compression ratio and more boost is better because under normal driving is where you spend 99% of your time and i would much rather be driving around on a low compression motor than high
Wiseco may not have a shelf piston that will work, maybe Diamond does, possibly mahle or jE does.
I'd do some more looking around. You certainly don't want to deck the hell out of the block, doing that is moving everything lower in the block, towards the bottom of the sleeve which isn't a really great idea, also decking that much off the block is bound to cause some alignment issues with the intake on the heads, pushrod lenth is gonna change, all that crap.
And to answer the question about how strong the piston will be with a 6.1 rod, yes it will be strong that's not a problem, with a 6.1 rod you'll have a good bit of room to put the ring lands down on the piston, the pin will be farther away from the bottom ring too, which never hurts.
