Quench and Gasket size
4.127" Bore
4.0" Stroke
6.125"Rod Length
68CC Combustion chamber
.030" Piston to Deck (in hole)
-25CC dished pistons
44 ADV intake close angle
228 ADV intake duration
240 ADV exhaust duration
114 lobe separation
110 intake lobe centerline
Also, would like to keep compression around 9.5:1
__________________
Don't lose any sleep over that thin gasket, Just use a MLS gasket like Cometic. keep the quench as tight as you can without the internals crashing together, It will help keep the dreaded detonation away
First of all we need to find out if quench is even a concern for you.
What kind of pistons do you have? If the dish in your pistons looks like factory dish pistons (like a round bowl) forget worrying about quench because the pistons don't have a quench area to worry about. Good aftermarket dished pistons are made that only the valve relief area has the dish, then a flat area for the quench. Usually they have a bathtub shaped dish.
So if you have decent pistons like I described, usually 0.040" (including head gasket) is optimum. I've build motors with quench as tight as 0.030" (including head gasket), but that's getting risky. Anything above 0.050" quench and you've lost all benefit of having good a good quench.
So if you can get a 0.020" or less gasket or 0.00 deck the block you could run a 0.040" head gasket, either way you'd be in good shape.
George Semper-Fi
