Switching from gmpp to L76
Old Dec 10, 2008 | 10:45 AM
Ryans_pewter_ss's Avatar
Default Switching from gmpp to L76
I was gonna see what ya'll thought about me swapping from my gmpp carb sytle intake to a direct port L76? Its a 6.0 L92, mild cam. Doesn't really feel like it makes alot on the bottom end, I usually only run 1/8th mile. The bottom end is not built or anything. Just wondering if this will help my combo?
Old Dec 10, 2008 | 10:55 AM
Can someone move this? Thought i put it in external section.
Old Dec 10, 2008 | 01:48 PM
alocker's Avatar
Are you running a carb or EFI with an elbow? Either way, unless its an FI or race motor, you should pick up a bunch of torque below 4000 RPM by going to the L76.
Old Dec 10, 2008 | 02:20 PM
EFI, It feels good now but I heard it would pick up torque, Thats what i want since i don't rev high enough to get the power out of the single plane
Old Dec 10, 2008 | 03:29 PM
alocker's Avatar
Are you running an elbow?
Old Dec 10, 2008 | 07:22 PM
Yes, aarons elbow
Old Dec 10, 2008 | 09:34 PM
03 BUSA's Avatar
Expect that intake to die at 6k. If it is a street car fine but if you are looking for a track number forget it.
Old Dec 10, 2008 | 10:06 PM
the_merv's Avatar
It pulls higher than 6K..mine starts to die at about 6500..
Old Dec 11, 2008 | 06:10 AM
Its not a race car or a dd, But i usually only run the 1/8th. I figure with it not being a solid roller or forced induction the single plane isn't really helping. I just wanna try to see if it feels better.
Old Dec 11, 2008 | 06:23 AM
WKMCD's Avatar
A 6.0 will take more RPM to max the L76 than a larger build. They actually work OK on the 6.0's if not over-cammed.
Old Dec 11, 2008 | 06:27 AM
not a big cam at all, 228-232 630/600 112lsa
Old Dec 11, 2008 | 06:29 AM
WKMCD's Avatar
The L76 should be a good match for that cam in a 6.0.
Old Dec 11, 2008 | 06:31 AM
Thanks man, Thats what i'm looking for!
