Ls9
Old Feb 24, 2009 | 11:52 AM
  #41
Haans249's Avatar
Originally Posted by DutchmanSS
I would say it would void the warranty if you modified the blower. I will try to get some installation info on an F-Body install.
Not trying to hijack the thread, but I was just on GM Performance webpage, put the Tall Deck LSX block in the cart with a dealer local to me, and said its available within 5-7 days. Is the tall deck shipping now?
Old Feb 24, 2009 | 12:06 PM
  #42
jmilz28's Avatar
LPE has the 58x to 24x conversion module, which solves most of the headaches. You will also need some sensor harness extensions and injector plug adapters. If you go LSA, then you don't have to worry about dry sump issues/relocation, etc. GMHTP has an LS3 swap with all the details, the LSA would be the same. Make sure you have a good fuel pump. Should make for a wicked swap with factory reliability if you do the details properly.
The only unknown I can think of is the TB. Is the DBW required for the LSA? If so, this may be the only issue. With the LS3, you won't need it once you swap to a cable TB.
Old Feb 24, 2009 | 12:26 PM
  #43
DutchmanSS's Avatar
Former Vendor
I just called GM on the LSx Tall deck...Part # 19166097. It says it is a future part not yet available. let me do some more research.
Old Feb 24, 2009 | 12:29 PM
  #44
DutchmanSS's Avatar
Former Vendor
they should be shipping anytime soon. I just got off the phone with GMPP.
Old Feb 24, 2009 | 02:09 PM
  #45
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Any modification to the engine at all will void the warranty, you definitely can not mod the blower. The warranty can be covered by your local dealer as well, so you don't have to ship parts out and wait.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Feb 24, 2009 | 02:25 PM
  #46
Haans249's Avatar
So you could drop this thing into your f-body, and if something breaks with it, they will cover warranty as long as nothing on the motor has been taken off/modified?
Old Feb 24, 2009 | 02:37 PM
  #47
DutchmanSS's Avatar
Former Vendor
Yes,GM will cover it.
Old Feb 24, 2009 | 02:45 PM
  #48
DutchmanSS's Avatar
Former Vendor
Right now GMPP does not have any info on swapping the LS9 into F-Body.
Old Feb 24, 2009 | 06:50 PM
  #49
OnyxSilveradoSS's Avatar
is the intercooler brick with the cover or is that another part?
thanks for looking for us
here are some pics...for those of us who need them
http://www.gm.com/experience/technol...LSA_Marine.pdf
thinking outloud:
Belt routing?
Fuel lines look like another part?
I think you could keep your AC?
I bet they are the stubby injector??
the other guys are selling 1900 set ups for almost $6k
Old Feb 25, 2009 | 03:56 AM
  #50
Qwick98Z's Avatar
Thanks for the info.
Old Feb 25, 2009 | 10:04 PM
  #51
GIGAPUNK's Avatar
Dutchman, can you confirm the price/availability of the LS9 oil pump individually?
Thanx!
Old Feb 26, 2009 | 08:29 AM
  #52
Thanx!
It's the LS7 pump, so it's available.
__________________
Old Feb 26, 2009 | 08:53 AM
  #53
Big Bird WS6's Avatar
thinking outloud:
Belt routing?
i dont think the lsa will work in a f-body. the intake port is sat at a angle.
onely the ls9 will work.
dutchman. just wondering but is there a part number and price on the lsa?
and do you have cam specs on either of the mtors(ls9 or lsa)?
Old Feb 26, 2009 | 09:22 AM
  #54
LSA = 19211708
LSA cam is 198/216 .480/.480
LS9 cam is 211/230 .562/.558
I can't quote prices, as this isn't my thread, just helping with some info
__________________
Old Feb 26, 2009 | 09:52 AM
  #55
GIGAPUNK's Avatar
I was under the impression that the LS9 oil pump was of higher capacity to make up for the pressure/flow lost due to the oil squirters, and would have a different part number.
Old Feb 26, 2009 | 10:06 AM
  #56
DutchmanSS's Avatar
Former Vendor
As stated the LS7 Pump is the same as the LS9 part # 12623097. It would be a 3-5 item from me. It is coming out of my Willow Run Parts plant.
Old Feb 26, 2009 | 10:18 AM
  #57
GIGAPUNK's Avatar
Thanks guys! Guess I was mis-informed.
Old Feb 26, 2009 | 11:26 AM
  #58
Riverracer's Avatar
What's the difference between the LS3, LSA, LS9 blocks besides the piston squirters? Can the piston squirters be easily added to the LS3 block?
Old Feb 26, 2009 | 11:36 AM
  #59
I guess I should have asked this earlier but seems there are more than one post about this.
LSA vs ZR1 blowers and misc stuff?
were the numbers listed for the ZR1 or the LSa?
is there anyway to see the break down of the LSa blower/misc parts?
TIA
Old Feb 27, 2009 | 11:36 AM
  #60
Riverracer's Avatar
I am selling them at $21,000. I highly doubt I will sell any,it would be nice though. Most people in my area do not have that much money to spend on a motor.
Does this mean the LSA will be about the same price as the LS7? If so, I would consider the LSA to be much better value than the LS7.
