My 454 LSX NA Build
just a heads up, i went thru 2 Meziere EWP's in 6 months and will never ever buy 1 again. i definitely wouldnt reccomend daily driving with one of those, as it took a **** and overheated instantly. for 10rwhp its just not worth it in my mind.... but nice build and great parts (minus the meziere).
Yea im going to have erik spec me a cam, chris and erik both feel a lil smaller cam will yeild more power anyway.
cool, i just dont wanna see a badass engine take a **** because of piece of crap meziere. you still gonna keep the 4.56's?? i think the 3.42's would be better suited since u'll have an assload of torque at 1,500 rpm lol.
I def. not gonna go with 3.42's
I want some short gears under me.
4.56's or 4.11;s I dont know why but for some reason i just figured i want really short gears...
Ill be running a 13.5" wide slick, and theyre like 28.5" dia....i should be fine on traction.... maybe... LMAO
i just checked out a speed/rpm calculator...
If i run 4.11's with a 28.5 dia tire at 7000RPM in 4th 1:1 Ill be at ~145 which i wont reach so i think ill go with 4.11's....
With the 4.56's I can only go ~133 in 4th... when i make it past that id have to shift.
I gotta say, your build sounds real cool BUT......
This is the WORST build thread EVER.
I've seen 2 pics of your throttle body and a stock intake pic, couple of boxed control arms........
C'MON Man, give us some damn pics!!!!!!!!!!!!
Im home now. So now now ill be putting a bunch of pcs up. Ill have some for you tonight.
If your giong with WCCH heads, they are nice pieces.
Harland sharp Does make LS7 rockers, I have a set on my LS7 heads. If nobody has them listed, you might have to contact H S. I called them directly. This way you have rollers on both pivot points.
4.56 Rear axle ratio for a daily driver?
I went with a Dana S60 3.73 . it's Great. About 1900 @ 80 mph with 315's on the back. @ 3600lbs with me in it, it has tons a torque. 1st, 2nd and 3rd it will break em loose.
Have not tried a pass at the track yet but if I can shift good enough, I'm thinkin 10 sec?
Evans makes a hi flow stock water pump n works well.
I need to get off my A * * and get some numbers ..
Good luck with your build
Well its been slow around here. Been home three days, and been sick... But i got out there today and finished laying down the first layer of Raamat today. Tomorrow im gonna
go out and put another couple layers on the firewall and the tunnel. Also im gonna lay
down the ensolite and test fit the old carpet
The part # for the H S rollers for the LS7 2006 > present is SLS78A
If no resellers list them, contact HS direct @
http://www.harlandsharp.com/contact.htm
I had a couple of pics of em but they were deleted.
I had to use SDPC valve cover spacers and had to shave off the corners a lilttle so they'd fit o-k. Other than that, no problems with em.
BTW, They mount on the exsisting rocker pedistal on the LS7 head, no shaft required. You'll also need a shorter pushrod. I used pushrods 7.6 inches long. I put another post with the part number so people can retrive it doing a search.
