441 high compression build
Old May 26, 2009 | 10:24 PM
peedeerooster's Avatar
Default 441 high compression build
Guys, I am looking at building a 441ci short block, 15 to 1 compression build with ported LS7 heads on race fuel only. It will be with an aftermarket intake for a carb. The engine will be built to turn 8000 rpm's with a powerglide and whatever stall is needed. I am putting it in a mud racing truck, ie no street use. Do any of you engine guru's have any idea how much flywheel horsepower I can make going in this direction. I am trying to go in this direction to save some weight. I am building an s10 to put the engine in. Thanks.
Old May 26, 2009 | 10:35 PM
venom ws7's Avatar
SlickVert on here made close to 900 Flywheel HP the engine was Build by Allan at FMS
Search his name on the dyno section or Call Allen
Old May 27, 2009 | 09:46 PM
SICKSS/Z28's Avatar
sounds like a waste of power
Old May 28, 2009 | 09:24 PM
UGotBeaT's Avatar
Depending on whos doing the heads manifold should make 900 +
I know Erik @ HKE is doing a setup that sounds pretty close to what your wanting to do.
Cesar
Old May 29, 2009 | 10:03 PM
Why would it be waste of power, if a mud racing truck is what I am building. Everybody has there own agenda. I thought it may be the right thing to do to make great power and save some weight. Building an egine for mud racing and saving weight made me think about this route versus adding the weight to run a big block. In mud racing, it is all about keeping weight down with alot of horsepower. Just like drag racing, horsepower to weight ratio is of utmost importance.
Old May 29, 2009 | 10:08 PM
Do you think that it is a waste of power just because I am not putting it into a drag car? You build a car, I am building something different. Each to his own agenda. Thanks.
Old May 31, 2009 | 01:30 PM
UGotBeaT's Avatar
Where are you located? I know alot of the mud trucks are around here in the south..
Old May 31, 2009 | 02:17 PM
mikey's Avatar
LS1TECH Sponsor
This one made close to what you are looking for.
http://www.rapidmotorsports.com/Rapid_TA_Small.wmv
