Ticking only with throttle, could this be a bad lifter? VID!
http://www.youtube.com/watch?v=pv5IyWXL8dc
So, what do you think? Bad lifter?
I have been breaking YT 1.7 rockers, three so far. I heard this new noise, pulled the valve cover, no broken rockers. I've been in contact with Tony at AFR. He got me in contact with YT's American source.
I am getting frustrated. Running 7.4 push rods. Guess I am going to have to measure for pushrod length.
Pics of broken rockers: http://www.facebook.com/album.php?ai...4&l=b733bd4eef
Come on, 16 views and no one will even comment? Am I posting in the wrong forum? It is an LS3 block, IV Gen. And I am quite sure it is internal.
It could be a lifter. Sounds pretty eratic to be one though. When my lifter went bad it was a constant tick. The best thing to do is pull the heads and check. That way you can eliminate the guessing.
Thanks for the reply, but I already pulled the valve cover and the rockers are fine. The noise, when driving, is only audible when throttle is applied. But, when the hood is up and engine is running, well, it is as you see in the vid.
Are you all able to view the pics on my Face Book page? FB says the album is public, so you should be able to view it.
Thanks again.
Thanks again.
I am using LS3/LS7 lifters. I do not know what the lifter preload is.
Yella Terra is being very helpful with the broken rockers. I have been in contact with thier VP of Sales and Marketing, and he is going to replace the entire set of rocker arms I currently have.
Thanks for your responses guys.
Brent
Well, I feel like an idiot. I trailered my Camaro up to LG last week and they dove in. The ticking was an exhaust leak. Passenger side header was loose. And the reason the rocker arms were breaking? Well, can't say we're 100% on this, but they think the springs were too strong for them. They changed the rockers from the YT 1.7 to stock LS1 rockers. And you know what? This car has never run more smooth, almost feels like it is stock again.
Thanks for your input guys.
