ls3 valvespring specs
Old Sep 23, 2009 | 01:40 PM
Greg Fell's Avatar
Default ls3 valvespring specs
anyone have them handy? how much lift, lbs on seat, open, coil bind etc.
Old Sep 23, 2009 | 08:14 PM
Robin L's Avatar
LS1Tech Sponsor
They are the same as an LS6 and the LS2.
IIRC they are good to .570 lift
I would need to look up the pressure.
Robin
Old Sep 23, 2009 | 08:40 PM
Greg Fell's Avatar
Thats enough for me Robin, thanks. I know exactly which springs they are now.
It looks like the 918's from comp are no longer rated at .650. Whats the deal there? What other options do you guys know of?
Old Sep 23, 2009 | 08:43 PM
SweetS10V8's Avatar
There rated to .625", Im running them at .621" lift right now and had to shim every single one of them still to get them where I wanted them.
Old Sep 23, 2009 | 08:52 PM
Greg Fell's Avatar
Really? Is this a different part number than the ls6/2? FYI I'm wondering for an 2010 camaro ls3.
i'm 99% sure the ls2/6 springs weren't good to that much lift...am I dreaming?
Old Sep 24, 2009 | 11:00 AM
Greg Fell's Avatar
ttt anyone confirm for sure? tia
Old Sep 24, 2009 | 11:11 AM
69LT1Bird's Avatar
From the GMPP catalog
12586484
Valve Springs (not shown)
• Beehive style springs • Standard LS6/LS3 springs
• Use cap P/N 10166344 • 1.250" @ 295 lbs. pressure
• 1.800" installed height • Max lift .570"
@ 90 lbs. pressure
Old Sep 24, 2009 | 11:17 AM
Petraszewsky's Avatar
I believe SweetV8S10 was referring to the Comp 918s
Old Sep 25, 2009 | 06:42 PM
Spectre86's Avatar
I think the 918s are rated at .600 and the 921s are rated at .650
Old Sep 26, 2009 | 07:33 AM
SweetS10V8's Avatar
I was..
Old Nov 28, 2009 | 10:06 AM
SS Enforcer's Avatar
So a custom hotcam grind with 218 550 550 112 would slip into a ls3 without a springchange ?
I don't care about skimping out on springs but want a light valvetrainand not bash the hollow valves around with heavy duty double springs
Old Nov 28, 2009 | 11:21 AM
69LT1Bird's Avatar
LS3 Valve spring specs.
89 lbs closed valve
294 lbs open valve
1.800 installed height
