schwanke engines
If it is a long-block a warranty should be included, but any shortblock should not exhibit any visible tolerance issues when arriving to the customer. There should be no need to tear down anything to ensure it's assembled properly. That was the builder's responsibility and not the customer's, nor the installers.
But I personally would buy the parts myself and have all the machine work done, it's not difficult at all to create your own company or find sum buddies that could get you the parts at cost and you wouldn't haft to go through the hassle of rebuilding an already built short block.
I am curious as to just how much you can check without some disassembly of the shortblock? Not much. I turn my own wrenchs on everything i own but would never tear down an assembled short block to re-check.
But I will admit I almost tore down my performabuilt trans to check proper clearances and **** before I installed it but that would void the warranty. So I didn't
You then made numerous replies where you tried to justify your postion about any motor that is purchased by anyone needing to be torn down and checked. So, your opinion is that anyone who buys a motor needs to tear the motor down (even if that person has no idea what they are doing). If they do not, they are lazy, and are equally to blame for an issue.
As I said earlier. If you want to tear down your motor, thats fine. Thats your cartainly an option open to YOU. But, where I take issue with it is the assertion that anyone who doesn't follow your lead is lazy, and also to blame.
Something we can both agree on is that humans do make mistakes. But, there are steps that if followed can virtually eliminate all the items you listed. its called a build sheet. When you build an engine, you document everything as you do it. Then you verify your work. When you do this, you virtually eliminate the chances of an issue with a missed clearance, or a torque value.
BTW, that is only a partial build sheet. Ther eis about twice that much info when its all done.I know a lot of builders who won't or don't this becuase its time consuming. But, if a motor comes apart you have documented proof of what it was when it left your hands.
The issue from a engine builder's perspective if you tear apart the motor they did for you and re-assmeble it is they have no idea of the skillset of the end user. You can always say "I know all about engines" but what you really know is relative.... People's curiosity outstrips their abilities all the time.
The biggest issues I see with most builds (shops or individuals) are people not keeping engines clean during assembly. I see this a lot more often than wrong clearances.
You end up with trash in an oil galley and it eats the motor alive very quickly. I saw a 408" motor last week that someone had installed an intake of a blown up 346. They failed to clean out the intake, and upon initial firing of the engine it swallowed some debris from the old motor and broke a piston on a brand new motor.
I saw another 408 recently that the bearings were eaten up in. We had to pull the reluctor ring off the crank and found that the crank had been shot blasted, and the shot was stuck up behind the crank. Again, improper prep.
Evan, the point is is your came into the thread and offered your opinion as the only right one. i.e. if you buy it and don't check it, you are at fault. You can say I'm trying to flex some e-muscle, or whatever. The point I'm trying to make here is that not everyone has the time or inclination to tear apart a brand new motor to check the work of the builder who did the work. The idea behind paying someone to build an engine is to avoid having to do that to start with.
Now, are you wrong for doing an inspection of your motor (once you get one). No, you are not. In fact, I commend you on taking the initiative to learn something. But, the whole point is the folks who are unwilling, or unable to do so are not "guilty", or at fault, despite your opinion to the contrary.
Also, I fully appreciate that when someone spends the money on an engine, they want it to be "right". I think everyone is entitled to that. But, the issue I see is that there is there are a lot of folks on both sides of the fence (both shops/builders and end users) who don't have a clue what they are doing, or just don't care.
I am going to make this the last post in this thread since it has gotten so woefully offtrack. If the OP wants to opena new thread, feel free. If so, I'd like to see it remain factual and not be based on hersay or 3rd hand info.
