WARNING: if order Federal Mogul pistons
If you order federal mogul pistons ,thats Speed Pro and Sealed Power you could be in for a long long wait .I ordered a set of pistons back in July,and have yet to receive them .So if your planing a build around there pistons ,you could end like me, frustrated and disgusted with FEDERAL MOGUL .There supposed to ship them by end of next week ,but I don't believe them,Ive got bad feeling, because they have lied a number of times before.IF anyone knows of a manufacturer that has a hypereutectic Flat top 4.030 bore let me know.I will keep you posted if and when they deliver!
I don't know what kind of pricing you got on the cast pistons, but if you are interested in comparing, Mahle's powerpak forged pistons which include rings, pins, and locks may be close enough in price once you add all the odds and ends up. They usually ship in a day or two... Let me know if you'd like a quote. Also, a couple of my vendors are showing stock on a 4.030 hyper piston, so if something falls through, I may be able to help there as well.
Thanks,
Shane
Thanks,
Shane
Thanks,
Shane
Thanks,
Shane
the speed pros' are around 400$ shipped with moly rings,wrist pins. use oe wrist pin diameter, not .927.
i got no problem with said heavy pistons with a 490rw 7k rpm n/a motor, that has seen 200 dose on ocassion and have around 38k miles
Thanks,
Shane
Thanks,
Shane
Gregg, The Mahle's will not have piston slap. That is one of the best things about those particular pistons. I will PM you a price on a set and check on the other cast ones as well.
Thanks,
Shane
Thanks,
Shane
what is the compression height and wrist pin diameter of these mahle pistons?
The particular part number is LS1340030F04. It is for stock rod, stock stroke applications. The compression height is 1.340 they are for stock .945 pins, have -4cc valve reliefs, and weigh 404g ea.
Mahle's part numbers are easy to translate:
first 3 characters are the engine family LS1, L92, LS7 etc...
second 3 are the compression height 340=1.340", 105=1.105", etc...
the third 3 are the bore dia 030=4.030", 898=3.898", etc...
the last 3 designate design and cc's F=flat top, I=inverted dome, D=dome, 04 would be -4cc in this case.
Shane
Shane
No slap, is this with forged pistons? just wondering how they have made the piston different?
The Piston to Bore clearance required and the skirt design on those pistons contribute to a very quiet piston. I have many very happy customers running around with these pistons with no slap even in 4" stroke applications. They come standard with Grafal skirt coating as well.
Shane
Shane
Well I received my pistons today,the mahle forged . I took them directly to the machine shop,happy to get my build going again.I will ask my parts supplier in a couple days ,if federal mogul ever shipped the ones I had ordered,just curious.
Well I talked to my parts supplier earlier this week and he said those Federal Mogul pistons still have not come in yet.Im so glad I didnt keep waiting for them.At this rate it does not look like they be shipped this year.We are starting the assembly this week on my build, just waiting on the crank to come back.
