using LS3 injectors w/ ls1 harness questions
I'm swapping to L92 heads and an ls3 intake on an lq4 bottom end using my stock ls1 harness.
my question is is it better to use ls1 style injectors I already have green top 42lb'ers but the intake im looking to buy comes w/ ls3 injectors so its a toss up.
with the ls3 injectors I'd need a harness adapter correct?
and the 42lb'ers I'd need a spacer for the fuel rail?
just looking for some clarification.
Chad
Chad
I can't find the fuel rail spacer on your site could you PM me or post the link please?
Chad
LS1Tech Sponsor
http://www.sdparts.com/product/KATA4...dapterKit.aspx
for using LS1 injectors in LS7 but the LS3 inj is the same as LS7....so those should fix you up.
I meant using the ls1 42lb injectors...you said there was a fuel rail spacer?
Chad
