LS2 bottom end max hp?
Old Nov 18, 2009 | 07:32 AM
Coonass350's Avatar
Default LS2 bottom end max hp?
hey guys how much hp/tq can the stock LS2 bottom end take before it gives out? possibility i will be spraying. just trying to find a combo of parts right now and looking for some info on the bottom end and how much it can SAFELY handle with a good tune
Old Nov 18, 2009 | 07:43 AM
NastyC6's Avatar
250 shot,.......600rwhp ,auto. Sean Freese Tune,back in 2005. never hurt the motor.didnt wanna pay to find the limit.
Old Nov 18, 2009 | 07:56 AM
Coonass350's Avatar
haha alright man thanks.
Old Nov 18, 2009 | 11:07 AM
1lejohn's Avatar
I would say between 600-700rwhp. The pistons and rod bolts are the weak links. Alot would depend how good of shape the motor is in to start with. You can do any thing once or twice. 500 rwhp you can do repeatably.
Old Nov 18, 2009 | 07:56 PM
bryanracing95's Avatar
how many times did you spray the 250 shot........ I thought 150 shot was the "safe" high point for spray in stock bottom end ls2's?
Old Nov 18, 2009 | 08:05 PM
Coonass350's Avatar
is this true? is a 150 shot the safe limit for the LS2 bottom ends?
Old Nov 18, 2009 | 09:38 PM
hivoltagedriver's Avatar
Slowgoat was spraying 200 on his LS2 running 10.3x's. I think that car had more "Gas" run through it then gasoline. Motor was still running fine when pulled for a stroker at 65K. I hear the crank is good for 1000, but the rod bolts are the weak link.
Old Nov 18, 2009 | 10:35 PM
Coonass350's Avatar
wow, these bottom ends are stronger than i thought, thanks for the info!
Old Nov 19, 2009 | 12:43 AM
LS6427's Avatar
Put in some good rods and pistons...take it up to 900-1,000 hp with the stock crank. Don't think one has ever been broken, but they flex which causes problems.
Old Nov 19, 2009 | 10:41 AM
Devils Mentor's Avatar
Thanks for posting this question man, I was wondering the same thing. I will be running a turbo and looking to get into the 700whp range so this has been on my mind.
DM
Old Nov 20, 2009 | 08:03 PM
NastyC6's Avatar
over 50 times
Old Nov 20, 2009 | 11:49 PM
Coonass350's Avatar
Originally Posted by NastyC6
over 50 times
haha damn thats good to know. and it had no problems?
Old Nov 21, 2009 | 12:55 AM
bondosgto's Avatar
550 safe. a lot of guys are around 600. over 600 is a crap shoot
Old Nov 21, 2009 | 10:45 AM
NastyC6's Avatar
No problems,.... Sean Freese tune, 600rwhp w/ an auto, bone stock Ls2. Sold that block, looked nice inside, I use nitrous as my piston cleaner,...ha,ha..
Old Nov 21, 2009 | 06:30 PM
A. Slone's Avatar
I'm at or just above 600, rods and pistons are gonna be your only problem. best bet is just to throw a set of rods and pistons in er' and call it a day.
Slone
Old Nov 21, 2009 | 11:34 PM
Coonass350's Avatar
Slone
alright appreciate the advice.
Old Nov 22, 2009 | 01:01 AM
turbogarrett's Avatar
Is this the ls2 shortblock you sold me? I know you said it was from a "bone stock c6"
Old Nov 23, 2009 | 06:11 PM
Andrew R's Avatar
NastyC6 no response?
An engine that has been shot with a 250 shot 50+ times is not bone stock. I'd take non response to this as a "yes I fucked him"
Old Nov 23, 2009 | 08:13 PM
Coonass350's Avatar
haha damn
Old Nov 23, 2009 | 08:15 PM
theantirotor's Avatar
Seems as though NastyC6 is a total lying assbag!
