The great mystery turbo cams
Hi all, just about to upgrade my motor to a
408 LQ9 TT AFR's and all the other goodies??
The bloody cam, for FI, the greatest mystery of all??????????
i have had a-
N/A 252/254 .620 112LSA loved it mad sound a bid sluggish until higher RPM![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
FI 228/235 .600 117LSA ok quiet idle potentially good turbo cam.![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
I want the best of both worlds for my new cam, can this be done???????????????
I want my ne 408 TT to fly, but on idle have that mean sound???????![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
Please help oh great cam gods![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
PLEASE
i have had a-
PLEASE
LS1 Tech Administrator
In my opinion, if you want the best of both worlds, choose a cam with low overlap and have your tuner keep the idle speed low and idle timing low. This will make for a healthy lope, even with a mild cam.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
i have had a-
PLEASE
i have had a-
PLEASE
If you want a cam the works the best-it's not going to sound that aggressive-the cam i had in Fireball's 1800hp LS2 sounded like a 224 cam
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
__________________
I suppose I use the term "closer to an NA cam" fairly loosely. I think you would agree that as the pressure differential approaches 1:1, you can use overlap more in your favor. Perhaps not 29 degrees of overlap like his original NA cam
, but probably more than 0 degrees at .050". Again, this is assuming a pressure differential close to 1:1 (which typically only race cars achieve).
Hi guys I need some help....I have a LS3 that I am about to turbo charge....The turbo that will be going on it is a GT4502R Im from Australia and I dont think Garrett Makes these spec turbos for the states so please refer below for specs. Im after a lumpy *** cam what would you suggest would work best with the LS3 and the turbo Im putting on it? Any of the turbo comp cams do the job? If theirs any more info you need about the car let me know.
GT4502R
Compressor Housing AR
0.72
Compressor Wheel Inducer Size (mm)
76.58
Compressor Wheel Trim
56
Turbine Wheel Exducer Size (mm)
71.42
Turbine wheel Trim
76
Turbine Housing AR
1.05
GT4502R
0.72
76.58
56
71.42
Turbine wheel Trim
76
Turbine Housing AR
1.05
There were only a few different cam-shaft designs available to hot rodders, and they were commonly known as either 3/4-race or full-race cams.now a days Cam manufacturers offer hundreds of profiles to choose from, and they go to great lengths to take the mystery out of their products.
