ls1 heads on a 6.0 ls2?
Old Jan 21, 2010 | 02:27 PM
drift donkey's Avatar
Default ls1 heads on a 6.0 ls2?
Has anyone ever put a set of 853 cylinder heads on a 6L ls2 block? I know they will fit and I know its a down grade, but I'm on a bugdet and this is what I've got. I have a ls6 intake with a ported throtle body. I think that will help a little. I plan to ugrade to the 243's sometime down the line, but just want to know if anyone has done this and if they still made in the 350hp or better range.
Old Jan 21, 2010 | 08:10 PM
any thoughts?
Old Jan 22, 2010 | 01:34 AM
baezi z06's Avatar
Originally Posted by drift donkey
any thoughts?
you could putt 241 heads on ls2 and make it work but i think you where slowing here down there, but if you would port them maby ?????
And then i would open up the chambers for bigger bore on each side next to the valves, should be better.
the same if you use 243 i would open up the chambers... too.
good luck
Baezi
Old Jan 22, 2010 | 08:29 AM
99T/ATIME's Avatar
I wouldn't do it. If you look you could find a set of 243 (LS2) heads for cheap....I have a set just sitting.
Old Jan 22, 2010 | 06:51 PM
thanks for the advice guys
Old Jan 23, 2010 | 04:19 PM
m5q8's Avatar
my camaro:
https://ls1tech.com/forums/generatio...head-dyno.html
Old Jan 23, 2010 | 08:07 PM
mtuggle86's Avatar
I can understand being on a budget I was two for my cam/head swap. But if I was you I would just wait and find a set of 243's. I payed 450 for mine brand new. I Then turned around and sold the ls6 springs they came with for 60 and my old 241 heads for 175. so I got better flowing heads new valves/guides/seals for 215 bucks IMHO If you planning on swapping on a set of 243's later Id just wait its far to much work to do later just to save 215 now.
Old Jan 24, 2010 | 06:10 AM
the_merv's Avatar
Wait and find some better Heads..
