Anyone built 482 LSX GM?
To make a 482ci, you would hypothetically need 4.250 bore x 4.250 stroke. It would be a trainwreck of a build, that would have poor gasket seal, loud pistons, and most likely use oil. Sleeve length has alot to do with it.
Hence we're using a 1.270" compression height piston vs. .990" piston you would need for 482ci build
4.185 x 4.000" ; 4.155" will have better gasket seal
You look at the bores, 4.185 or 4.200, its thin between the bores.
When you run a 4.185" bore you can use a 4.200" MLS gasket, all shelf parts, rings sizes are common etc. If I recall cometic goes up to 4.210" for gasket bore size. 4.250" you would need, copper gasket.
I'd say the topic has been beaten to death more then once on here.
Remember that more isn't always better..
No matter which block you go with all LS blocks are 4.4" BS. They will
all have same gasket dimensions.
People use 4.250" bore size with a 4.5" bore space SBC
Heres other issue, you go for the 4.200" bore size later on after its been run and needs freshen up. No room to bore the cylinder. If you start at 4.155/4.185 you leave some options later on.
With the RHS block, they have difficulty keeping the bores round over 4.175" bore size.
Good info about the RHS block.
We are using 4.165 bore for our build.
Sleeve an iron LSX tall deck block, 4.250 stroke x 4.155 bore...461ci.
Plenty of gasket, plenty of piston support...tons of cylinder strength.
