Does a L92 Front Cover work with LS1 Accessories?
My question: What front cover do I need? Do I need a new cam sensor? Do I need to switch timing chains?
Are these the two parts I need? "-12596023 Early LS2 1x Timing cover w/cam sensor-Supposedly later style 4x will work. 12588670 LS2/LS3 Black Timing Chain Tensioner"
AJ
I'd like to keep the VVT if at all possible.
1lejohn...did you swap out the VVT stuff? Did you change your cam?
https://ls1tech.com/forums/conversio...g-vvt-l92.html
Maybe I'll CNC my own spacers.
Look at this links is everything you need to convert to ls1
https://ls1tech.com/forums/generatio...02-f-body.html
https://ls1tech.com/forums/generatio...-ls2-swap.html
Absolutely untrue. Not trying to flame you man Im just trying to clear up some facts. AFM ( active fuel management ) has the funky spring lifters that collapse and are for fuel efficiency. VVT (variable valve timing ) is the phaser on the front of the cam that moves the cam advance/retard relative to RPM for optimal power. If you took a cam with identical specs and installed one with VVT and one static ( no VVT ) the VVT cam will make more power under the curve. In no way at all does VVT hurt performance it is a power adder hence why its banned from Formula One racing engines and the like. Also the Escalade and Denali 6.2L early years only came VVT and NO AFM hence the standard LS7 lifters. If your building a performance VVT engine these are the best to start with.
Beaflag VonRathburg your right that thread is handy and we should add it to a sticky somewhere
The issue I have is that I have now is that I have the OEM L92 front cover from a Denali with the VVT part that sticks out rather far. From what I can determine from reading that thread is that my OEM Fbody accessories will not work with the front cover I have. I may need the thinner LS2 vette version. That may work out as I am missing the cam sensor, bracket, wiring, and one of the bolts that holds the VVT sensor onto the timing cover. It may be similar in cost simply to buy a new front cover.
