Scat or Eagle?
Old Jul 2, 2010 | 08:15 PM
racer7088's Avatar
Arrow
Originally Posted by slowride
Does scat make a on center rod for ls1's? I thought they were all off set from small block apps? Not that they won't work, just asking.
What do most think of the k1 stuff?
FWIW the SCAT rods are only .015 offset so they are almost on center. The normal SBC is more like .030-.035 offset. I don't know why SCAT did it like that but it makes it easier to use them on LSx stuff at least than other normal SBC stuff.
Old Jul 3, 2010 | 08:54 AM
slowride's Avatar
Any word out on the new compstar cranks that are made from a different alloy? I've seen them sell in the $500-600 dollar range and figured they would be great for NA builds, etc.
Old Jul 3, 2010 | 10:42 AM
supermouse4's Avatar
Callies is using 5140 steel for the $500-$600 cranks, supposedly they can handle more than 500 hp, which is great for budget guys and their builds.
Here's the link:
https://ls1tech.com/forums/generatio...er-cranks.html
Old Jul 3, 2010 | 11:32 PM
Gordon0652's Avatar
Learning alot on this thread about the crankshaft differences, intresting...
Here's the link:
Thing is that 500hp is nothing for a crankshaft - (most?) stock LS crankshafts can hole 800-1000hp.
Old Jul 5, 2010 | 04:09 PM
Derek@KY-Turbo's Avatar
Callies Compstar, K1, Scat are my first three pics for a budget minded quality 4340 crank...They are priced competitively.
Old Jul 5, 2010 | 04:22 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
I REALLY like the Compstar C series crank. They help keep cost down, do not take alot to finish balance, and are readily avail. We have them in the 4" stroke and the 3.825 stroke. One of the local guys is building a 366 with an LS1 and the 3.825 crank on a budget. It will work out nice for him I am sure. He just got the crank and is waiting on pistons.
FWIW I have seen either Speed Inc or VA Speed take one of the C series cranks to over 700 HP on a turbo build. Good price and good quality and good availability.
Old Jul 5, 2010 | 05:18 PM
flatchat's Avatar
Hmmm a 366 sounds ok. Is that with a stock length rod? How would you go with pistons?.
I have heard the RPM international cranks and rods are a good bit of gear for the price has anyone else used them.I have a mate with one of there small block 350 cranks with no issues . What is the c series cranks going for.
Old Jul 5, 2010 | 05:23 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
They are around $569. Right now Keith Black makes pistons for the 6.125 x 3.825 crank and rods. They come with rings. I am sure I could mix and match a piston with a certain CH and either the 6.100 rod or the 6.125 rod and make it work. I had a combo worked up with a 6.100 rod, but it was easier to use the 6.125. More choices really.
Old Jul 5, 2010 | 09:50 PM
Jimbo1367's Avatar
what does "FWIW" mean?
thanks,
JIm
Old Jul 6, 2010 | 01:01 AM
Marktainium's Avatar
For What It's Worth
Old Jul 6, 2010 | 11:31 PM
I know RPM International sells alot of their product as private label parts. I've seen some good cranks/rods for sbc and sbf engines, however I've never seen the parts for a LS engine...From what little I know about the company all their products are forged/machined overseas...You will probably get what you pay for with their items...
