Can a GTO front accy drive work on an LS7?
Hey guys..
already searched but with vague answers..
can the front accy drive from a later model GTO work on an ls7?
Im doing a swap on my 67 camaro and i want to know if it would work.
thank you!!
thank you!!
![](http://chzsomuchpun.files.wordpress.com/2010/04/129165187301869262.jpg)
LS1Tech Premium Sponsor
All of the accessory bolt holes and provisions are in the same spots between the LS2 and LS7. You should be good to go without any issues (other than the dry sump and such as mentioned already).
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Matt - don't you need a spacer for the crank snout if you're running the dry sump crank? I seem to remember that there is an issue with the pulleys lining up.
Yes, as stated the dry-sump does require some changes...but everything else has the same provisions. I forget who makes it, but there is a spacer you can run so you don't have to modify that stock LS7 crank to run the standard GTO/F-body crank pulley.
__________________
If they make a spacer for all the accy drive that could work, but the simple solution is to leave all the accy drive in original location and move the damper back into the stock location.
Kurt
Kurt
