*** CAUTION*** Crankshaft Porn
Old Jul 23, 2010 | 11:43 AM
Eddie Krawiec's Avatar
Exclamation *** CAUTION*** Crankshaft ****
Well here it is. I waited 14 weeks and for it. It is a 4.100 Billet Center Weighted Crank made by Winberg Crankshafts. This thing is a killer. As you can tell by the pictures I had it also micro polished. If you are building I would say to look into their stuff.
Enjoy, I almost don't want to use it.
You can also follow the engine and car build here :
https://ls1tech.com/forums/drag-raci...aro-build.html
Attached Thumbnails *** CAUTION*** Crankshaft Porn-photo.jpg   *** CAUTION*** Crankshaft Porn-photo-1-.jpg   *** CAUTION*** Crankshaft Porn-photo-2-.jpg   *** CAUTION*** Crankshaft Porn-photo-3-.jpg
Old Jul 23, 2010 | 11:50 AM
built408's Avatar
That looks to nice to even use.
Old Jul 23, 2010 | 11:53 AM
melsie68's Avatar
Very nice but I am surprised to see a reluctor wheel on it. I would have thought to say the level of engine that requires such a crankshaft would use something a little better than the factory style pick-up. Maybe using an external crank trigger or distributor? Regardless very nice. What is the application?
Old Jul 23, 2010 | 12:41 PM
DBN's Avatar
DBN
That is a beautiful piece of art Eddie. Good luck with the Pro Stock motorcycle. I never miss an episode.
Old Jul 23, 2010 | 12:53 PM
davidws6's Avatar
Damn, that is a nice piece !
Old Jul 23, 2010 | 01:15 PM
Jontall's Avatar
Nice... I'll give you $50 for it, right now.
Old Jul 23, 2010 | 02:06 PM
BgBoost1's Avatar
WOW....a piece of ART! Thanks for sharing!
Can you give us a ballpark of the cost?
Also, what is the weight?
Old Jul 23, 2010 | 02:14 PM
1320's Avatar
I bet......over 4000........?to the door...
pretty......but dam......expensive.
Eddie, if you come to vegas and want to make a few passes on my turbo busa let me know.
Old Jul 23, 2010 | 03:04 PM
Thanks
I don't plan on running the reluctor wheel.
As for the weight it is right at the 44lb range.
As you see it with the polish it would be roughly $4000. But it would depend on how much weight it took to balance it. Most shops charge you for the metal and that can make it vary.
It will be going in a 439ci tall deck LS motor. I will have the block next weekend so maybe now I can get this motor together.
Old Jul 23, 2010 | 03:40 PM
AES Racing's Avatar
4.100 stroke with tall deck, what length rod you planned to run and from who? Looks good.
Winberg cranks......... just ordered one for a 5.3 block
Old Jul 23, 2010 | 04:03 PM
The rod is a 6.450 Carrillo H-Beam.
Old Jul 23, 2010 | 04:24 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
Make sure to order the small base circle cam! Ask me know I know lol.
Gm in the infinite wisdom did not raise the cam tunnel, and running a large stroke with a long rod (H beam even) causes some problems with cam clearancing.
You should prob be ok with the 4.100 stroke though.
We ran into issues with a 4.600 crank.
Old Jul 23, 2010 | 04:30 PM
Damian's Avatar
LSX Mechanic
That's almost too pretty to put inside a block.
Old Jul 23, 2010 | 04:53 PM
odarabla's Avatar
^^^^^^^^ Agreed!!
Old Jul 23, 2010 | 05:28 PM
supermouse4's Avatar
Amazing work there, I'm jealous.
Old Jul 23, 2010 | 05:38 PM
racer7088's Avatar
Very nice. Windberg makes awesome stuff for sure!
Like you said you hate even using it as it should have it's own pillar to sit on and look down on the rest of us!
Old Jul 23, 2010 | 05:41 PM
AES Racing's Avatar
Eddie is running RHS tall deck with raised cam.
are you referring to LSX tall deck?
Fraser
Old Jul 23, 2010 | 05:46 PM
XtraCajunSS's Avatar
Absolutely beautiful... Should look just like the one I'm waiting on to arrive...
Congrats.
Shane
Beau@SDPC's Avatar
LS1Tech Sponsor
Yes, I was referring to the GM piece. I should have known he would use the RHS. Better choice but more money obviously. And that does not seem to be a problem with this build though. Esp when the crankshaft costs 2 times the GMPP LSX Tall deck block.
Old Jul 23, 2010 | 05:56 PM
99tramsamc/fia's Avatar
Now my pants are all wet!!!!
