LS3 build questions strokkker vs blower
Any opinions or suggestions are welcome.
Boyd
get an ls3, put new pistons in for boost, then make sure the exhaust is up to the task, since that blower will flow better than most headers can handle.
I guess not many people are interested in A Pantera with an LS motor. I am not getting many suggestions (1 to be exact) My plan was to go with 180 degree headers. I have hall big bore headers and mufflers (Pantera Proprietary) now.
Go to Super Chevy web site and search Project Getaway. Their you will see the engine build with details.
we also got this nice 2300 package-makes 900bhp and idles like stock
https://ls1tech.com/forums/dynamomet...00-901bhp.html
The reason I ask is a heat management issue, with a stroker you will have more heat versus a stock config, and with forced induction more so.
When I did my rebuild I could've gone twin turbo or SC but opted for a stroker because the additional power would have been harder to control on the track and I was concerned about heat as I was roadracing in south Texas at the time.
Have WCCH do yo a set of L92(LS3) heads with lightweight intakes, run a solid roller valvetrain and produce 600 streetable horsepower with a 7500-8000 redline.
That will be plenty of power in the car without the expense and heat of supercharging, and the RPM will keep you out of the gearbox while still giving you the top speed you want.
https://ls1tech.com/forums/new-produ...6hp-427-a.html
