Need advice on Cam-Only LS3 Vette I'm Looking at...
I am in the market for an LS3 Vette. I've found one that I like, but it is already fairly modded, and I'm a bit worried about the drivability with the cam that is in the car. I'd like to get opinions on how a car with the following cam (and supporting mods) might be as far as in-town driving manners, and also how bad of a hit fuel economy will take (yes, I know, its a performance car....got it). Here are the mods:
Cam specs are .612/.610, 244/242
Comp springs
Kooks headers and X-pipe
Callaway intake
Underdrive pulley
Ported throttle body
Ram clutch with Fidenza aluminum flywheel
Engine made ~490 RWHP and ~430 lb/ft.
Any thoughts would be greatly appreciated. I'm not very familiar with LSx cams, but this one sure seems to be rather large for something that I want to drive around town a lot. Hope I'm wrong!
Thanks!
Bob
Comp springs
Callaway intake
Underdrive pulley
Thanks!
Bob
^^ what he said
and before that too. Its a big cam, but not too big to be 'drivable' tuned well. if you like the curve itll be a blast, 430 torque is sure to be something you can feel, even if being a large cam makes it more top-end-happy, but itll be all about how you diggit
I appreciate the input so far. The main reason I'm trying to get comments/opinions is because the car is NOT local, and thus I cannot take it for a test drive.
Bob
Bob
If you do deceide to purchase it I would definately have it gone through by a reputable shop. They can check the caliber of the work as far as the install of the parts and the tune uploaded to the car. I would look up Virginia Speed , they are in your area and have an excellent rep here on the forum.
Buying an already modded car can be a double edged sword. On one hand you can save quite a bit of money if your were planning on moding the car, on the the other your gambling on what was really done to the car and how it was treated.
Either way good luck with your purchase.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Joe
Comp springs
Callaway intake
Underdrive pulley
Thanks!
Bob
Comp springs
Callaway intake
Underdrive pulley
Thanks!
Bob
Thanks again for the input. Forgot to add that the cam has a 112 lobe sep. Here's a video... http://www.youtube.com/watch?v=4zC3nEyOslk
Pretty sure this post is about the car I'm looking at: https://ls1tech.com/forums/corvette-...y-results.html
The ptv in a ls3 with a cam on a 244 intake has to tight. Way beyond the safe zone. Unless they flycutt. I personally would check on that. Also intrestesting that they are runnning a reverse split cam in a ls3.
Edit- i see its a hpe megadeath cam. I would be concerned about ptv clearence with this one in a ls3 for sure. Wrong cam for a ls3. There are ls3's with much smaller cams making those same numbers. Also the 1 7/8 headers are not helping the torque. Whenever you cam a ls3 you should have 1 3/4 headers. When camed the ls3 likes a little back pressure.
It almost sounds like it does not even have muffs...
But at any rate good luck, I bet its a mean ride.......ha ha ha
Bozz
Tin Foil Hat Wearin' Fool
redsap05....many thanks for the insight!
Uh....Bozz. I appreciate your concern. However, I"m hardly a "beginner" and have no interest in "creeping", or "sneaking", or being worried about the police. But again, thanks for your concern.
"ha ha ha"
Bob
"ha ha ha"
Bob
https://ls1tech.com/forums/gen-5-cam...hp-451-tq.html
I have a 08 ls3 vette bolt on's with the LG G6X3 cam. It's specs are pretty close to that cam. There is some low rpm bucking at low speeds but its not bad even with the RPS street twin lite clutch and flywheel. Are you the Bob Cosby that ran factory stock with the 99 cobra in nmra?
On a ls3 whit the stock cam the 1 7/8 headers are ok. However when you cam the ls3 the 1 3/4 will get you better torque. Many of the corvette guys can vouch for this with the ls3 on the vette forums. Heres a great thread about it.
A buddy of mine picked up 40rwhp by going from pacesetters to kooks 1 7/8-2 headers on a h/c ls1. Youre talking about a motor with more cubes and heads damn near what his ported cheapo heads flowed. I realize the intake to exhaust ratio is different on LS3 heads but that only goes to show it needs the exhaust to be evacuated better. Why do you think ALL of the big number LS3s are running 1 7/8 headers?
You need to get off the internet and out into the real world more often, or at the very least take a reading comprehension class.
