what will the compresion be on a ly6 .030
Lunati 60531 should work good for long travel sand car.
It is a 227/238 lift is in-583 ex-600 on a 112, this was made for the l92 head.
if I have 9.7 compression with a .051 head gasket what will I have if I use a .030 head gasket?
Thanks.
If pistons are .010 out of the hole as they normally are, you wont want to run the .030 gaskets. you'd be better off milling the heads.
This is a stock 2009 ly6 I am milling the heads. how about what is the compression ratio for .030 off the head and a .051 gasket,
