Input on cam for L92 setup
Old Jan 19, 2011 | 12:00 PM
Quick99TransAm's Avatar
Exclamation Input on cam for L92 setup
218/228 .525.525 on a 112 lsa heads are milled .025 full bolt ons.Just looking for a mild cam
Old Jan 19, 2011 | 12:15 PM
87silverbullet's Avatar
The concensus has been that you would need more split that that for a motor with l92 heads. Talk to Geoff@EPS or PatrickG on here and let them spec you something for your power goals.
Old Jan 19, 2011 | 06:24 PM
Default Bump
up top
Old Jan 19, 2011 | 06:43 PM
WKMCD's Avatar
10 degrees is plenty of split. I've run 6-8-10 and 18 degrees of split. The best cams had 6-8-10 degrees of split. You can run a whole lot more lift and be just as mild with more power.
Old Jan 19, 2011 | 06:47 PM
lemons12's Avatar
Ten is plenty of split.. I'm no expert on them but after talking to a few something in the 8 range tends to be the magic split.
Old Jan 19, 2011 | 09:42 PM
1CAMWNDR's Avatar
Looks like the GM Hot Cam. There are much better cams out there....
Old Jan 20, 2011 | 05:10 AM
Thats not the same cam you posted before when I made my first post. You had something like 224/228 with 6 something lift on a 113. Why did you edit your post and change the cam?
Old Jan 20, 2011 | 07:09 AM
gtotoocool1's Avatar
actually the GM hot cam keeps up with most of the "L92" spec cams until the higher rpms.one of the magazines did a cam comparo and the results were suprising.
Old Jan 20, 2011 | 10:25 AM
Default Cam
Sorry for the bait and switch.I went on your recommendation for more split.
Old Jan 20, 2011 | 11:49 AM
Its all good Good luck with you cam choice.
Old Jan 20, 2011 | 06:39 PM
Default Cam
up top
Old Jan 20, 2011 | 07:09 PM
Ragtop 99's Avatar
how mild?
i'm putting a 226/234 115 in my vette. At 0 overlap it should have nice manners.
