LS 427 / 8800 rpm / dyno results?
I am looking for a dyno graph of LS427
RHS heads
10:1 compression ratio
2,2" intake valve / 1,651 exhaust valve
250-260 cams.
Max engine speed 8800 rpm
Does anyone have a dyno graph of a similar project?
Cheers,
DD
RHS heads
250-260 cams.
Cheers,
DD
Here's something a little more constructive. An 8800rpm 427 has a lot more than 10:1 compression. An 8800rpm small block is very expensive. Here's an example of an extreme build https://ls1tech.com/forums/dynamomet...aspirated.html . What are your goals? Get with a great builder and you'll enjoy the money you've spent instead of being pissed off @ some half *** builder.
Here's a 9000rpm dyno pull with a GM ls7 bare block.
http://www.youtube.com/watch?v=PaxE6dsfb_o&NR=1
