Stupid oil pickup tube and pump. Figured out why, but have new problem.
I installed a Melling 10296 in my LS3, which is still in the car. There is a gap now where the pickup tube goes into the pump that wasn't there before. I know this because I took a picture of the stock setup before I removed the factory oil pump. It is about the thickness of the o-ring and I felt it and noticed the o-ring bunching up and not going into the pump. I used the green O-ring because visually it seemed the same size as the factory red one.
After seeing the gap, I put the factory pump back on and it has the gap too. No amount of tightening closed the gap. I tried the factory o-ring too and had the same results.
Any advice?
UPDATE:
Well... I figured out why it wasn't going in. I cannot believe I didn't see it until now. The mouth of the pickup is out of round. I put 2+2 together when I put an oil pump tube girdle on it and it still wouldn't go together as easily as it should. I took the pump back off (broke my 10mm ratchet wrench in the process). I looked inside the pump and saw a piece of metal that was being shaved off. I glanced at the pickup tube and then noticed it was out of round. I guess I boogered it up when I removed it.
Engine builders out there... can I make it round again with a pair of channel locks or something and go from there or do I have to get a new pickup tube? I hope I can make it round, at least round enough to go in correctly. The part where the o-ring rides is still round. I am not looking forward to it if I have to take the engine out. I will probably cut the cross member out that is under the pan and install it that way. I can then either make the cross member bolt in or have it welded back in.
Any advice?
UPDATE:
I am running a C5R chain.
I spun the engine over a few times before each attempt to tighten up the bolt. The tube is tilting towards the bolt side when tightening down.
I ordered one of the pickup tube girdles so it will evenly close the gap hopefully if I give each bolt a couple turns and go back and forth between them.
