LS3 or LS7 Heads for 430 Stroker??
Feel free to suggest ideas
And I'd throw the PRC line-up into the mix for you to consider
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Make sure the piping going to the TB is a straight shot. Any bends in the intake can suck up 10-20rwhp. ie 90* bends
Get an LS7 cylinder head specific camshaft. They like a lot more exhaust duration than intake. I have a QM600 cam in mine.
Here is a good read on LS7 cams and some vendors you can contact:
https://ls1tech.com/forums/generatio...running-2.html
