PRC Aftermarket Casting 250cc LS3 Cylinder Heads In Stock & Available!
Just wanted you guys to know we now have the all new PRC LS3 aftermarket casting cylinder heads in stock & ready to ship!
PRC's aftermarket casting LS3/L92/L99 Cylinder Heads come standard with the following options:
NEW PRC 13 Degree Valve Angle LS3 Castings
Improved P/V Clearance For Extra Compression & Larger Camshafts
Smaller Than Stock Intake Port Volume For Greatly Improved Velocity
Manley Stainless 2.165" Intake, 1.59" Exhaust Valves
Your Choice of Spring Kit
Completely Assembled and Milled to your Specifications
60-68cc Chambers
*USE LS3 Rockers & Intake For Easy Install!!
Checkout the flow data & specs on our site @
http://www.texas-speed.com/p-3200-pr...der-heads.aspx
60-68cc Chambers
![](http://www.texas-speed.com/images/product/large/3200_1_.png)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
LS1Tech Premium Sponsor
They have a custom valve so we won't be selling them bare. I'm very reluctant to sell any of our aftermarket casting heads without valves. The valves are a very important part of the whole cylinder head package. The PRC LS3 heads use longer valve so we can get the spring pocket up away from the port.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
They have 6 bolt ears.
Install height completely depends on the spring configuration your running. I have a set here @ 1.850", but with a few retainer tweaks & lock changes I'm sure you could get 1.900".
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
Formerly Low_LQ4 - 6/6/10
I'm getting ready to order the heads next week just need to know what gaskets do I use with these heads for a Bore x Stroke (in): 4.06 x 3.62 (103.25 x 92 mm)?
So what is the deal with your small bore LS7 heads? I've seen them posted saying they are ready for shipment , but no listing at the TSP website. I am interested in flow data and options. Flow data seems to be asked for alot. Just saying.
I've been getting the link for these heads last week. But when I would click them or *add to cart*......... they would say..... "no longer available" Glad to see them availble now.
Ok........ I just seen your 429 signature. LOL
