Clearance for 3/8 pushrods - LS3 heads
Last one I checked there was at my estimation .050 all the way around a 3/8 .080 wall Trend pushrod, with heads that were unmodified in the pushrod area.
If it tickles the side of the aluminum a bit while running, like stated above...not a deal killer (but not a good idea if you can clearance it first).
If it binds up and you can't turn it over easily...obviously you need to drill the holes out a bit
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
