Max bore size on iron 5.3
Old Feb 18, 2012 | 10:16 PM
TurbopigB4C's Avatar
Default Max bore size on iron 5.3
Has anyone tested the limits of the bore size on the gen iv 5.3 iron blocks? I have heard that some have gone out to 4.000" safely. Is there anyway to tell without just doing it and possibly ruining the block.
Old Feb 19, 2012 | 04:15 PM
KCS's Avatar
KCS
Moderator
Sonic check it. That will tell you how much material you have, but I'm not really sure how much material you want to be left with ater it's been bored and honed. That's probably dependent on power/RPM.
Old Feb 19, 2012 | 07:36 PM
Good to know. I guess they are pricey but do most machine shops have them? http://www.ndtsystems.com/Automotive...ndard_pkg.html
Old Feb 19, 2012 | 07:41 PM
I was reading around and it says to leave around .200" thickness to be safe. So I guess if it sonic checks at around .420" or higher I can have it honed to 4.000" safely right?
Old Feb 19, 2012 | 08:12 PM
bww3588's Avatar
If that's the case, you need to think about if it's worth it. Remember, a machine shop will probably charge you for 2 bore jobs maybe more to take it out almost a quarter inch.
Once you factor in that cost, it may be cheaper to get a good 6.0 block and have it honed .005 or at most a .025 bore and a hone to 4.030
Old Feb 19, 2012 | 08:38 PM
I have had no luck selling the new 5.3 block I bought for a project I sold. I mine as well use it instead of letting it go to waste and my camaro is down for a rebuild anyways so I have the choice of having all the machine work done on the stock ls1 block or building the iron block. The shortblock is still good just high mileage and I had a pushrod break so its apart. I likely could have more interest in an assembled shortblock and get around 600 for it so it will offset my build.
Old Feb 19, 2012 | 09:07 PM
bww3588's Avatar
Very true...how much you looking to get for the 5.3?
Old Feb 19, 2012 | 09:49 PM
200 but I do not want to ship it because I do not have a crate and the freight companies don't insure anything just on a pallet. Local pickup in socal.
