LS3 valve spring problems...HELP!!!please
Pat G spec'd me a cam and I got the TEA .660" lift valve springs as recommended. Was told to set the spring height at .050"-.080" before coil bind.
Well, that would be 1.810" to 1.830"
My problem is there's only 1.770" available. The machine shop said I'd have to cut the spring pockets, use offset valve locks (if available) or by .100" longer stem valves.
Has anyone else had this problem?
TIA
Hell call TSP, or EPS and see what they reccomend.
Ugh
